Android Auto with OnePlus Two?
  1. cezarvrabie
    Jelly Bean Oct 4, 2015
  2. v1rk
    Gingerbread Oct 5, 2015
    v1rk , Oct 5, 2015 :
    No app is needed, its built within the os like mhl
  3. cezarvrabie
    Jelly Bean Oct 5, 2015
    cezarvrabie , Oct 5, 2015 :
    The description suggest that you need it for Android Auto to work.
  4. v1rk
    App its already Installed with Lollipop
  5. mactoni
    Jelly Bean Oct 6, 2015
    mactoni , Oct 6, 2015 :
    I installed the app and nothing. Tried different oh options. The car is VW Group model and we tested with samsung galaxy range and HTC and worked perfectly. I think the problem is the port
  6. dar88rm
    Cupcake Oct 18, 2015
    dar88rm , Oct 18, 2015 :
    it's a pity. I have just bought a new car. I will have to sell the OPT. :mad::mad::mad:
  7. cezarvrabie
    Jelly Bean Oct 18, 2015
    cezarvrabie , Oct 18, 2015 :
    Sell the car lol jk
  8. dar88rm
  9. XSized
    Froyo Dec 22, 2015
    markgranto likes this.
  10. markgranto
    Honeycomb Dec 22, 2015
    markgranto , Dec 22, 2015 :
    that's good to know, getting a new car soon, most likely a skoda with smart link, can you advise what apps will work with it? google maps, spotify etc?
  11. Deactivated User
    Dec 22, 2015
  12. XSized
    Froyo Dec 24, 2015
    XSized , Dec 24, 2015 :
    Play Music, Spotify, Google Maps, Hangouts (you hear the message and can answer via voice) WhatsApp (same as Hangouts)... that's what I use daily
  13. markgranto
    Honeycomb Dec 24, 2015
    markgranto , Dec 24, 2015 :
    Exactly what I'm looking for, cheers!
  14. sergilun
    Gingerbread Dec 24, 2015
  15. cantonadiangirl6
    Eclair Jan 15, 2016
    cantonadiangirl6 , Jan 15, 2016 :
    It definitely works :) I bought the phone for my fiancé and wanted to make sure it worked with the new Honda 2016 civic android auto capability. My OPO works with a USB 2.0 cable (not the existing one) and I bought a separate Orzly usb-c to 3.0 usb-a cable for his OP2. Everything works. Make sure you first download the Android Auto app and have your Bluetooth on to avoid any issues.
  16. sfallon36
    Donut Feb 3, 2016
    sfallon36 , Feb 3, 2016 :
    My OPT on Oxygen 2.2.0 works fine with my Pioneer AVIC-F77DAB, in fact it's brilliant. I'm lucky to live in a strong 4G area which helps with data for navigation and streaming music on Spotify.
    Also I found that enabling Smart Lock and making the head unit a trusted device makes things a lot smoother. The phone doesn't like to connect if its locked.
    Android Auto also requires a physical USB link, sometimes I get the impression that some people think it can be done via Bluetooth.....
  17. XSized
    Froyo Feb 3, 2016
    XSized , Feb 3, 2016 :
    That's the only issue I have. My OPT asks me ALWAYS if I want to add my car as trusted device and I accept. But next time it asks again... Haven't found any solution so far.
