8
[Submitted] Android Auto
  1. moebius1024
    Eclair Sep 30, 2021
  2. TrogloGatto
    Cupcake Oct 10, 2021
  3. nosciencehere
    Cupcake Oct 14, 2021
    nosciencehere , via OnePlus 6T , Oct 14, 2021 :
    Having the same issue with a OnePlus 6t, Android auto no longer recognized by my Nissan's head unit after the latest OS update. This is a new issue that only started occuring after the update.
    Oxygen OS 11.1.1.1
    Build A6013_41_210917
    Bectora likes this.
  4. ChrisWright1905
    Christian LHARIDON likes this.
  5. 39aatthompson
    Cupcake Oct 24, 2021
    39aatthompson , via OnePlus 7 Pro , Oct 24, 2021 :
    Updates on the Android Auto fix? Or I spent $600 on a useless piece of hardware. Running in circles looking for answers for months and months. Nothing.
  6. Nr456
    Cupcake Oct 27, 2021
  7. C1590003536684
    Cupcake Oct 28, 2021
    C1590003536684 , via OnePlus 6T , Oct 28, 2021 :
    Same issue after oxygen 11.1.1.1 with Android Suto not connecting.
    I can get it work after completing wiping out Android Auto, forgetting all cars, and powered off then reinstalling. It will connect once but as soon as I disconnect. It will stop working. Repeat process and it works for one connection. Same issue with three different rentals as well as my own car. Never had issues untill the oxygen 11.1.1.1 update.
  8. Y1635090186195
    Cupcake Nov 2, 2021
    Y1635090186195 , via OnePlus 9R , Nov 2, 2021 :
    I HAVE PURCHASED ONE PLUS 9R , ANDROID AUTO IS NOT WORKING IN MY PHONE .IT CONNECTS AND DISCONNECTS IMMEDIATELY.MY FRIEND PURCHASED THE SAME PHONE AND FACING THE SAME ISSUE.PLEASE DO SOMETHING TO RESOLVE THIS ISSUE.
  9. G_Brian_Green_TUMV
    Cupcake Nov 2, 2021
    G_Brian_Green_TUMV , via OnePlus 6T , Nov 2, 2021 :
    Same issue. Android Auto not working after Oxygen OS 11 update. Keep getting message " Android Auto cannot show on your screen, connect to a compatible USB port or use a different cable". Tried 3 different cables, no luck. OP 6T
    Frédéric L. likes this.
  10. fscata
    Cupcake Nov 3, 2021
    fscata , via OnePlus Nord 2 , Nov 3, 2021 :
    I solved this issue with my OnePlus Nord 2, Oxygen v11.3.
    Try following these steps:
    1) clear storage and cache of Android Auto app
    2) turn off Bluetooth connection
    3) connect the device to the car
    After the third step, the phone shows the application wizard to install Android Auto and following all steps I have been able to get the application working on my car.
    I hope this helps you!
    Francesco
  11. C1590003536684
    Cupcake Nov 3, 2021
    C1590003536684 , via OnePlus 6T , Nov 3, 2021 :
    I found a workaround that works with my OnePlus 6 and oxygen 11.1.1.1.
    1) open settings go to apps and notifications expand all apps select Android auto
    2) plug-in phone. if it doesn't display correctly on your screen unplug phone and then immediately Force Android auto app to close
    3) plug back in immediately and it should display said:
    this is been working for me for the last for 5 days
  12. LordGreyMane
    Cupcake Nov 4, 2021
    LordGreyMane , via OnePlus Nord 2 , Nov 4, 2021 :
    Found an additional solution. Have a new Nord 2 and a Sony AX5000. Phone would not connect from the minute I bought it.
    Solved it by doing the following -
    1. Turn on Developer mode by clicking build number several times.
    2. Go to Settings>Additional Settings>Developer Settings>Default USB configuration and change it to either charge or USB MTP.
    That's it. The phone was stuck in USB Ethernet NDIS mode and wouldn't connect to my head unit. Android Auto works perfectly now.
    G1635327633368 likes this.
  13. Frédéric L.
    Froyo Nov 8, 2021
    Frédéric L. , via OnePlus 6T , Nov 8, 2021 :
    I'm facing to the same issue. I've tried many reinstall, cash/storage clearing, BT off, wifi off... Absolutely no success.
    One of my friend who does not upgrade his Op6T and continue to run an oxygen 10 version is able to connect my car with my USB cable w/o any issue.
    Please OnePlus fix this issue, Waze, maps, and other Android auto features are missing.
