Android Core Apps Draining Battery
  1. I1509691813092 Cupcake May 16, 2018
  2. Jacek Pecka Ice Cream Sandwich May 16, 2018
  3. I1509691813092 Cupcake May 16, 2018
    I1509691813092, May 16, 2018 :
    not given a solution on Android Core Apps Draining Battery issue
  4. Jacek Pecka Ice Cream Sandwich May 16, 2018
    Jacek Pecka, May 16, 2018 :
    Are you sure that there aren't any information which can be useful?
    BTW - I've found a thread with the "Android Core App" too.
    But first of all you should provide more details - at least battery graph - we can't read in your minds.
  5. I1509691813092 Cupcake May 16, 2018
  6. Dunnow The Lab - OnePlus 6 Reviewer May 16, 2018
    Dunnow, May 16, 2018 :
    well to start, that fake wassap...
    that is possibly some shitty app you have installed that is pulling from services located at android core, and that is why it's reported as such.
    Maybe you should uninstall crappy apps or start denying permissions to them
  7. I1509691813092 Cupcake May 16, 2018
  8. I1509691813092 Cupcake May 16, 2018
    that I know but it's not issue of it, I'm using that since 5 yrs not had any problem regarding battery ! What is this android core app ? how can i fixed it
  9. Jacek Pecka Ice Cream Sandwich May 16, 2018
  10. I1509691813092 Cupcake May 16, 2018
  11. Dunnow The Lab - OnePlus 6 Reviewer May 16, 2018
    I'm not saying it's that 5 year old app. I'm saying, seeing you install shit apps, because that 5 year old one is, it's provably any other of the ton you might have installed.
  12. I1509691813092 Cupcake May 16, 2018
  13. I1509691813092 Cupcake May 16, 2018
    dear only gb WhatsApp I'm using and it's not an issue of it, I'm using same apps in my pixel 2 and other android phone too !
  14. Dunnow The Lab - OnePlus 6 Reviewer May 16, 2018
    don't call me dear please, it's quite unpleasant
    DrAakash likes this.
  15. I1509691813092 Cupcake May 16, 2018
    u hving any solution brother ! or make time pass
  16. I1509691813092 Cupcake May 16, 2018
  17. Dunnow The Lab - OnePlus 6 Reviewer May 16, 2018
    I already gave you a solution, you said it's all fine, then I'm done. It seemed clear to me.
  18. Jacek Pecka Ice Cream Sandwich May 16, 2018
    For 100% there is an app which is draining your battery and using the contacts.
    Check what apps are having permission to the contacts and you will know which app is bad boy.
  19. I1509691813092 Cupcake May 16, 2018
  20. I1509691813092 Cupcake May 16, 2018
