12
Android Nougat Experimental for Oneplus One
Would you try android n on your bacon?
  1. I'd wait for official cm14
    36.5%
  2. I like mm better than Android N
    2.1%
  3. Are you kidding me? Of course I'll try android N !
    61.4%
  1. Sanjoov
    Gingerbread Sep 1, 2016
    Sanjoov , Sep 1, 2016 :
    This ROM rocks. No major issues. Using as daily driver since release. Presently on 31st build.
    #41
  2. lokesh3440
    Honeycomb Sep 1, 2016
    lokesh3440 , Sep 1, 2016 :
    Extremely fluid ROM i must say. Multitasking at a whole new level. I have opened Chrome with 9 tabs(full desktop) in one part of Multiwindow and several apps like hangouts,gmail,facebook,whatsapp) in other part. Switching between apps is damn fast. No chrome tab got refreshed. It was really a surpising thing. I wonder if one plus one can handle Nougat like this,what level of multitasking would there be in One plus 3 having SD820 with 6 gb of ROM. Google has definitely done wonderful work in Android Nougat.
    #42
  3. royz0r
    Jelly Bean Sep 1, 2016
    royz0r , Sep 1, 2016 :
    thought u had a iPhone 6?
    #43
    JayminVyas likes this.
  4. Tarfex
    Ice Cream Sandwich Sep 1, 2016
    Tarfex , Sep 1, 2016 :
    Does Snapchat work? Or is that camera issue only for certain things?
    #44
    bright_wal likes this.
  5. Tarfex
    Gonna wait for the ROM tolrogress a bit more (fix any issues) and wait till Xposed comes out for Android N.
    #45
  6. djmoderate
    Eclair Sep 1, 2016
    djmoderate , Sep 1, 2016 :
    Snapchat works, but recording does not:(.
    #46
  7. Tarfex
    No point in trying out the ROM just yet then. I don't use Snapchat like crazy but still...
    #47
    bright_wal and se7enlyn like this.
  8. csabreu
    csabreu , Sep 1, 2016 :
    I don't use snapchat. But I guess the video features shouldn't work also for now, since it's an HW encoding related bug supposedly. For example, Duo starts by opening the camera, then freezes and FC. Same behaviour in Hangouts. Didn't tested in Skype, but should have a similar outcome. Screen cast doesn't work either. Therefore, if you happen to depend critically on apps that use video calls or recording on your daily usage, I suggest you wait until the bug is fixed.
    #48
    tye359, ziepicwaffle, Tarfex and 2 others like this.
  9. Ashishrocks
    Froyo Sep 2, 2016
  10. jjrojoc
    Froyo Sep 2, 2016
    #50
  11. 9620743706
    Froyo Sep 2, 2016
    9620743706 , Sep 2, 2016 :
    That CM14 is highly unusable. No calls, no wifi, just basic nougat features. So chill and enjoy this for the most part stable AOSP rom.
    #51
  12. csabreu
    Ice Cream Sandwich Sep 2, 2016
    #52
  13. d1beats
    Jelly Bean Sep 2, 2016
    #53
  14. JayminVyas
    Ice Cream Sandwich Sep 3, 2016
    JayminVyas , Sep 3, 2016 :
    Should be a quick one guys....the steps to install ROM+GApps on XDA still apply right? Flash ROM, SU, and any other customisation, but not GApps? Boot into ROM, restart, and then flash GApps?
    #54
  15. Ashishrocks
    Froyo Sep 3, 2016
  16. JayminVyas
    #56
  17. pandollar
    Donut Sep 3, 2016
    #57
    csabreu and ziepicwaffle like this.
  18. Angelooo1
    Honeycomb Sep 3, 2016
    #58
  19. d1beats
    Jelly Bean Sep 3, 2016
    #59
  20. d1beats
    d1beats , Sep 3, 2016 :
    I think the commands where for the first couple of releases. I didn't do them
    #60
    Angelooo1 likes this.
