5
Android Os and System draining battery? SOT < 4 hours
  1. G_Oliver_Moors_mitt
    Donut Apr 12, 2017
    G_Oliver_Moors_mitt , Apr 12, 2017 :
    Android OS and Android System draining battery life? SOT of about 3 ½ hours. Doze Mode in developers options enabled as well as aggressive doze Mode (also tried disabling)
    Android 7.1.1
    OxygenOS 4.1.1
  2. funnpun
    Eclair Apr 12, 2017
    funnpun , Apr 12, 2017 :
    I also have this problem. I factory reset my phone but SoT is still only 4hrs.
    validator771100 likes this.
  3. G_Oliver_Moors_mitt
    Donut Apr 12, 2017
  4. G_Taif_Rahaman_qnUB
    Cupcake Apr 12, 2017
  5. G_Luciano_M_BBSl
    Gingerbread Apr 12, 2017
  6. elanglois
    Lollipop Apr 12, 2017
    elanglois , Apr 12, 2017 :
    Sorry to tell you, but its WhatsApp. Freeze it and see what happens.
    Why do you need that anyway? If you could double your SOT, would you uninstall it?
    You can try to Greenify it.
  7. G_Oliver_Moors_mitt
    Donut Apr 12, 2017
  8. F_Alexandru_Dumitru_KKev
  9. G_Oliver_Moors_mitt
    Donut Apr 12, 2017
    abhinavw14 likes this.
  10. habeebsahili
    Froyo Apr 12, 2017
    G_Mr_.... likes this.
  11. habeebsahili
    Froyo Apr 12, 2017
  12. Sébastien Dreesens
    Donut Apr 12, 2017
    Sébastien Dreesens , Apr 12, 2017 :
    6hrs of Screen on time is good. i'm not able to get more than 4-5hrs. 100-60% -> 3hrs sot. but downwards 50% my battery drains extremely fast.
  13. habeebsahili
    Froyo Apr 12, 2017
    habeebsahili , Apr 12, 2017 :
    bro im just running doze mode in developer options and its giving me sot 6hrs try to enable it maybe it will work for you too
  14. habeebsahili
    Froyo Apr 12, 2017
    and turn off back up which is automatic backup
  15. Sébastien Dreesens
    Donut Apr 12, 2017
    Did everything but nothing's working. did a full wipe (incl. internal storage) yesterday. i'll see if it helps. thanks for your help c:
    habeebsahili likes this.
  16. G_mauro_cimino_ETaA
    G_mauro_cimino_ETaA , Apr 12, 2017 :
    for over a week I also have the same problem, I tried various factory restore but nothing. I also tried not to install apps and keep only those system to no avail. any other advice?
  17. akhilsunkara7
    Eclair Apr 12, 2017
    akhilsunkara7 , Apr 12, 2017 :
    cache cleared??
    if not do that first from recovery every time after updating .
    And one more thing disable aggressive doze and app hibernation if at all u activated doze mode in developer options
  18. akhilsunkara7
    Eclair Apr 12, 2017
    version of OOS??
  19. Himanshu16193
    Donut Apr 12, 2017
    Himanshu16193 , Apr 12, 2017 :
    yup.. same problem here.. battery drains when using my OP3T , but when i turn data off at night it stays to the same battery level throughout the night. is the problem because of cellular data?
  20. Sébastien Dreesens
    Donut Apr 12, 2017
