236
Android P Beta Developer Preview 3 for OnePlus 6
  1. thegreatv
    Gingerbread Aug 17, 2018
    thegreatv , Aug 17, 2018 :
    I am having issue only with paytm app notifications. Whenever I close the app the notification still remains and I have to go to manage notifications and manually close it from there always. Happening only for this app for some reason!
  2. reath123
    reath123 , Aug 17, 2018 :
    No am not using H2 os and one thing i want to know is this OTA update or need to flash it manually?
  3. x8xx8x
    Honeycomb Aug 17, 2018
    x8xx8x , Aug 17, 2018 :
    For some it's the battery percentage not synching right while it's charging , and for some it doesn't show anything at all.. it just says charging
  4. Humdeep
    Cupcake Aug 17, 2018
    Humdeep , Aug 17, 2018 :
    I've used the search for this however it's come up empty, hoping someone can advise, i'm looking at getting the OP6 today (currently on the OP3T). Do Pie's App Actions work on OP devices or is this a feature that we'll only see on the Pixel/Pixel Launcher?
  5. x8xx8x
    As of now it's just a pixel exclusive.
    Humdeep likes this.
  6. G_said_jabri_rIBx
  7. vriesdejoop
    Ice Cream Sandwich Aug 17, 2018
  8. vickysud
    Eclair Aug 17, 2018
  9. Virgiel
    Froyo Aug 17, 2018
  10. Tamukanashe Musengezi
  11. vickysud
    Eclair Aug 17, 2018
    vickysud , Aug 17, 2018 :
    ofc it was
  12. Virgiel
    Froyo Aug 17, 2018
    Virgiel , Aug 17, 2018 :
    maybe a little
  13. MangoDogi
    MangoDogi , Aug 17, 2018 :
    I personally hoped that OB update will come in this week, but now i think it won't come today :( so we'll need to wait to next week...
  14. MD_18
    MD_18 , Aug 17, 2018 :
    no it's fixed. also i did a dirty flash and everything is working smoothly. didn't even notice a single bug till now though the brightness slider is lil buggy though it works fine but auto brightness is working excellent. battery backup is so good in comparison to oxygen os. H2 os beta 1 is like the stable version coz there are no bugs. just clear the cache from recovery if you doing dirty flash.
  15. OPOBEAST
    OPOBEAST , Aug 17, 2018 :
    Can you still recommend installing DP3 on the Op6? Or should I just wait for the official drop?
  16. MD_18
    flash H2 OS beta one. it's the best currently.
  17. vriesdejoop
    vriesdejoop , Aug 17, 2018 :
    I will try it one more time...... as op6 has the a/b partitioning witch is needed for the seamless updates, wiping cache in recovery is COMPLETELY USELESS, because there is NO CACHE PARTITION ANYMORE.
    Wiping (deleting) something that is not there is useless advice.
    only wiping of the specific app cache in system can help with problems
    sorry for the capitals.. [e]1f61a[/e]
  18. sgmtnbike
    sgmtnbike , Aug 17, 2018 :
    My personal view.. I'm still using DP3 as a daily and really happy with it. Beta for O2 OS will be coming soon and I would wait for it. H2 OS is designed for the Chinese market. OP history shows when any Chinese beta gets released, the global beta won't be long. The differences in features and performance between DP3 and H2 OS isn't significant enough to switch when the beta will be coming soon.
    OPOBEAST likes this.
  19. MD_18
    the are far more than just significant. there are no bugs coz the open beta of h2 os is based on stable Android 9. it's the best you can get ryt now. Also you can remove all the Chinese stuff and also you can remove Google apps you don't want. Dirty flash will save you from downloading the play store app from 3rd party sites.
  20. sgmtnbike
    beta Oxygen OS should also be based on stable Android 9 when released. I'll just wait for it. DP3 is stable enough for me for now
