236
Android P Beta Developer Preview 3 for OnePlus 6
  1. paul67™
    Gingerbread Aug 29, 2018
    paul67™ , Aug 29, 2018 :
    Same way you installed H2OS over Oxygen Beta3.
    Oxygen Beta3 file in the root of your internal storage and then local install. Maybe full wiping after install (make a back-up) for best result. Want to go back to stable Oreo? You need to roll back (see first post how to do).
    sayantansasmal likes this.
  2. DC technical
    Donut Aug 30, 2018
  3. tortoise14
    Honeycomb Aug 30, 2018
    tortoise14 , Aug 30, 2018 :
    Because open beta project is going to start in few days.
  4. wleonardocruz
    Gingerbread Aug 30, 2018
    wleonardocruz , Aug 30, 2018 :
    It's sad that there is no progress after the Developer Preview. and that the H2O version is more advanced.
    tortoise14 likes this.
  5. Blazentaxer
    Cupcake Aug 30, 2018
    Blazentaxer , Aug 30, 2018 :
    Thanks but it didn't work using TWRP it said failed to write to correct partition or something. Instead I just did it using the local upgrade method by first updating to DP1 then DP2 then finally DP3. It worked perfectly and I'm now using DP3 as my daily driver.
  6. Blazentaxer
    I don't know where else to post this but this is just for the bug fixes... I'm running DP3 as my daily driver and it seems to be working fine other than that when I enabled the pixel gestures the swipe up to go to recents sometimes breaks and says that OnePlus Launcher keeps stopping. I'm not complaining, just informing that it is a bug and should be fixed because most people want to use the pixel gestures and the OnePlus gestures just aren't as good as the pixel gestures.
  7. MrStabsv1
    Froyo Aug 30, 2018
    MrStabsv1 , Aug 30, 2018 :
    In the new hydrogen builds the pixel gestures are fixed and can be enabled in settings.
  8. Horizon21000
    Horizon21000 , Aug 30, 2018 :
    But they still working only with the official launcher app, right?
  9. krisGamer
    Froyo Aug 30, 2018
  10. Blazentaxer
    MrStabsv1
    In the new hydrogen builds the pixel gestures are fixed and can be enabled in settings.​
    Ok thanks... but the issue is pretty minor and I can live with it till the open beta or next DP releases cus I'm not really in the mood for formatting my phone all over again and restoring backups. Thanks for the advice though [e]1f601[/e]
  11. MrStabsv1
    Froyo Aug 30, 2018
    No you can use any launcher.
  12. JohanSmolders
    Eclair Aug 30, 2018
  13. jebujohn
    Eclair Aug 30, 2018
    jebujohn , Aug 30, 2018 :
    but I am so pretty... so is it useless for me.
    AcmE85 likes this.
  14. heartless28
    heartless28 , Aug 30, 2018 :
    Try poco launcher. It's really clean, smooth and organized launcher. Im using it now and loving it.
  15. FCipher
    JohanSmolders likes this.
  16. Karl-Johan
    Eclair Aug 30, 2018
  17. prkoparkar
    Froyo Aug 30, 2018
  18. krisGamer
    Froyo Aug 30, 2018
  19. Caedbleidd
    Froyo Aug 30, 2018
    krisGamer likes this.
  20. krisGamer
    Froyo Aug 30, 2018
    Caedbleidd likes this.
