236
Android P Beta Developer Preview 3 for OnePlus 6
  1. ClarKent98
    Froyo Aug 31, 2018
    ClarKent98 , Aug 31, 2018 :
    if i download the open beta and after they release the official update i will get it ?
  2. beingrahulag
    Gingerbread Aug 31, 2018
    beingrahulag , Aug 31, 2018 :
    A bug in slow motion FPS 480 where camera gets stuck and doesn't respond until restarting the phone
    tried cache cleaning too, nothing seems to work.
  3. ObamaKaMama
    ObamaKaMama , Aug 31, 2018 :
    i have installed android p beta on my device and while installing my data was not wiped and it was intact.. only thing is i need to install the apps again..
    this was 2 days before and today suddenly all data on my storage got deleted, but still my app data is there.. only my contacts and storage got deleted..
    apps like whatsapp facebook, everything is there as it is without any data loss..
    does it impact anything in future..
    ps.. i have already taken backups of my data before installation
  4. wbgrunn
    wbgrunn , Aug 31, 2018 :
    It's common to have storage problems and other bugs, i had that too.
    Just like alot of other people here, factory reset and the problems will be fixed.
  5. ObamaKaMama
    after factory reset, will it go again to andriod O? or it will be Pie only
    and shall i take backup of my whatsapp before factory reset?
  6. wbgrunn
    You flashed P so obviously you will stay on P.
    ALWAYS take backups
    good luck
  7. F_Jonathan_Lee_JhRz
    Froyo Sep 1, 2018
  8. wleonardocruz
    Gingerbread Sep 1, 2018
    wleonardocruz , Sep 1, 2018 :
    They go slow, the launch may be it's together with 6T
  9. Z1524097572194
    Froyo Sep 1, 2018
  10. wbgrunn
    wbgrunn , Sep 1, 2018 :
    true but patiently wait or flash h2os/DP3 bro. These are stable roms
    paul67™ and wleonardocruz like this.
  11. paul67™
    paul67™ , Sep 1, 2018 :
    Try it out and you will see. I have no problems with network connections, drop outs etc H2OS is better working than Oxygen dp3 in my case.
    G_Devesh_Mehra_VVyC likes this.
  12. Z1524097572194
    Froyo Sep 1, 2018
    Z1524097572194 , Sep 1, 2018 :
    which country are you from ?
  13. paul67™
  14. paul67™
    I diid a dirty flash H2OS over Oxygen dp3 a week ago, works very good. No problems so far.
  15. ObamaKaMama
    ObamaKaMama , Sep 1, 2018 :
    could u provide the link to download h2os and step to install the rom
  16. Horizon21000
    Honeycomb Sep 1, 2018
    Horizon21000 , Sep 1, 2018 :
    Nobody said it would come out last week!
    OnePlus only promised that they will release the official Oxygen Android Pie version before December this year.
    Soon there will be Android Pie Custom Roms for the OnePlus 6 in XDA Forum. Don't worry!
  17. E380813
    E380813 , Sep 1, 2018 :
    They have already provided update on open beta in weekly update as published. It's currently under certification by Google and shall be released as soon as the clearance is provided.
  18. G_said_jabri_rIBx
    G_said_jabri_rIBx , Sep 1, 2018 :
    who also thinks that the brightness in H02 beta 3 is to low. I have to put the brightness almost at max to see it good. Is this a bug or is it standard in H02
  19. paul67™
    You are right. It's lower indeed. I put the brightness on auto. Works good by me this way.
    G_said_jabri_rIBx likes this.
  20. x8xx8x
    x8xx8x , Sep 1, 2018 :
    It's a standard feature now..that's how it is on Android p. It's the same on my pixel as well
    paul67™ likes this.
