236
Android P Beta Developer Preview 3 for OnePlus 6
  1. Horizon21000
    Honeycomb Sep 1, 2018
    Horizon21000 , Sep 1, 2018 :
    Have you done a factory reset after installing H20S?
    I had similar brightness issues with dirty flashed custom roms in the past.
    Otherwise if they really limited the maximum brightness it would explain why the maximum screen-on-time is longer on H2OS.
    paul67™ likes this.
  2. G_said_jabri_rIBx
    Gingerbread Sep 1, 2018
    G_said_jabri_rIBx , Sep 1, 2018 :
    did a factory reset still the brightness is thr same.
  3. paul67™
    paul67™ , Sep 1, 2018 :
    Try adaptive brightness mode, maybe this helps.
    Brightness is indeed lower, i have more
    benefit with the setting above.
  4. x8xx8x
    x8xx8x , Sep 1, 2018 :
    Yes I have. It has'nt changed anything..it was similar for me on dp3 as well
  5. AarKay2311
    Froyo Sep 2, 2018
  6. wleonardocruz
    Gingerbread Sep 2, 2018
  7. Horizon21000
    Honeycomb Sep 2, 2018
    Horizon21000 , Sep 2, 2018 :
    It came as an OTA Update? I am impressed!
    I think the focus of OnePlus is clearly on H2OS now. I think we will get the next Oxygen Android Pie Beta around 15.9. (the useal update date of OnePlus).
  8. wbgrunn
    paul67™ likes this.
  9. paul67™
    paul67™ , Sep 2, 2018 :
    Yes! The app display issue in recent app menu is fixed. Sometimes i had troubles with that.
  10. soldatcc
    Donut Sep 2, 2018
    soldatcc , Sep 2, 2018 :
    Not entirely apparently
  11. paul67™
  12. paul67™
  13. wbgrunn
    wbgrunn , Sep 2, 2018 :
    No problems. i had zero problems before the update so.. :)
    paul67™ likes this.
  14. paul67™
    Sometimes issues with recent app menu (see few posts back). Been solved now with latest update.
  15. wbgrunn
    i also Read that yes but didnt experienced any problems
  16. JoseReyes69
    JoseReyes69 , Sep 2, 2018 :
    My only issue with recent update haven't been able to get WiFi calling nor voice over lte to show.
  17. vriesdejoop
    Ice Cream Sandwich Sep 2, 2018
    vriesdejoop , Sep 2, 2018 :
    strange, it was working before? no problem for me
  18. Caedbleidd
    Froyo Sep 2, 2018
    Caedbleidd , Sep 2, 2018 :
    Did you enable VoLTE and VoWiFi through efs modification? And did it affect how long it takes to switch from 4g to 3g on your device too?
  19. vriesdejoop
    Caedbleidd
    yes, used the"German modification" method from XDA, the longer switch time I did not noticed, I don't see switching between 3g and 4g.
  20. Caedbleidd
    Froyo Sep 2, 2018
    hmm, cause it worked for me as well, but when I walked around and the connectivity changed it took a while until it changed and got connection again... I may have to look into this issue again, but thanks for the reply
