236
Android P Beta Developer Preview 3 for OnePlus 6
  1. taebom
    Donut Jul 18, 2018
    taebom , Jul 18, 2018 :
    I just did another clean install and everything works fine before magisk is flashed. On 16.6 after rooting, google apps stop working like chrome, gmail, and connecting to servers. Tried magisk core mode only and that did not work. Back to regular DP3 with no root and all apps including chrome working fine.
  2. QuentinH96
    Gingerbread Jul 18, 2018
    QuentinH96 , Jul 18, 2018 :
    i installed locally, rebooted, phone went into recovery,, wiped everything as that was the only way it'd let me reboot the phone, now it looks exactly the same abd Google lens still doesn't work lending me to believe something went wrong. I'll try again.
  3. Kambanka
    Froyo Jul 18, 2018
    Kambanka , Jul 18, 2018 :
    I'd second that - it's high time OnePlus thought of the normal update path with no data wipe [e]1f601[/e]
  4. prfraczek
    Honeycomb Jul 18, 2018
    Predict23 likes this.
  5. Its.Leandroo
    The Lab - OnePlus 6 Reviewer Jul 18, 2018
    Its.Leandroo , Jul 18, 2018 :
    They didn't ruin anything. Also, it's a developer preview, you knew it looks like this, so you could have stayed with Stable OOS 5.1.9 which is the same UI as the pixel phones.
    Instead of being rude, give normal feedback with arguments so OnePlus can actually do something with it.
    Easy.
    FlixbusLennart likes this.
  6. Its.Leandroo
    The recent app screen is almost the same idea as Google has made. So blame Google if you don't like it :p
  7. Moin2200
    KitKat Jul 18, 2018
    Moin2200 , Jul 18, 2018 :
    yeah after a few hours of use the only problems i've noticed is stability in some apps and the choppy home gesture, had to disable gestures for now.
    Also the new resents ui is neat though i would have preferred it going from right to left instead of left to right.
    But definitely daily driver material.
    Cheetosdust likes this.
  8. A1527082449033
    Froyo Jul 18, 2018
    A1527082449033 , Jul 18, 2018 :
    someone help me...
  9. _fas_
    Cupcake Jul 18, 2018
  10. hitesh.kr069
    hitesh.kr069 , Jul 18, 2018 :
    Yes the issue is there...
    I am using lawnchair alpha and the gestures are much better..
  11. arknu
    Eclair Jul 18, 2018
    arknu , Jul 18, 2018 :
    Glad to see this actually looks like Android P now Much nicer.
    However, can we please have the option of using the native Android P gestures?
  12. Whone99
  13. alexferdean
    Ice Cream Sandwich Jul 18, 2018
    alexferdean , Jul 18, 2018 :
    Not anymore. Maybe because I've installed the latest Pixel Launcher.
  14. QuentinH96
  15. alexferdean
    I've found a bug. I can't seem to skip in YouTube videos to where I want. I can skip only if I drag the red dot, but not if I click someone on the red line.
  16. derLenno
    derLenno , Jul 18, 2018 :
    It doesn't let me add my card on P. Might be related to too many re-adds in too less time or something. Like a security issue when you re-enroll your card 3 times a day. For me, doesn't work at the moment
  17. derLenno
    Exactly. I think they will offer updated gestures soon, now that the way is paved with a new recents logic (swiping left to right instead of up and down)
  18. G_Rich_Cowan_EQlj
    G_Rich_Cowan_EQlj , Jul 18, 2018 :
    if you want your op6 to look like a pixel..Then you should have bought a pixel! op are going to add their skin to android p. Thankfully it's very light and customisable. Like I said if your not happy sell it and get the Google phone...
    personally I love OnePlus take on android p!
    well-done OnePlus!
  19. prfraczek
    prfraczek , Jul 18, 2018 :
    NO it doesn't need to look like pixel but should keep android P style. Everywhere where the android in 'untouched' you can see nice animation, smooth transitions between windows, menus etc. Anything done by OP still uses old 6.0 style. And the whole point of getting OP was the almost clear android experience otherwise we would go for Galaxy s9 with crappy Samsung TouchWiz.
  20. x222
    Froyo Jul 18, 2018
    x222 , Jul 18, 2018 :
    I hope we will finally get fully black theme with white text and white icons in Android 9 ??
    and vibration control ??
    and Google camera app fully functional ??
    but very little hope is left after so many years of extremely poor development from Google team.
