236
Android P Beta Developer Preview 3 for OnePlus 6
  1. Marwadi_Rahul
    Froyo Jul 19, 2018
    Marwadi_Rahul , Jul 19, 2018 :
    just one question...may be its a big disappointment as well..
    why oneplus why ?
    please give us the stock UI, like you gave us in Nougat...
    fine that you still had Nougat UI in Oreo....but isn't it worst to still not change UI in P ?
    Google has done fabulous job with Android P UI but why you guys are hell bent on destroying the taste of Android P.... why waste all the developer resources in just theming the stock UI to old Nougat way....
    OP6 is a great device..and with Android P we wish it would be butter smooth....so please bring the Stock UI with Oxygen OS useful features...
    + give us an option to use something useful like Google feed instead of Shelf.... its a waste of prime space on Home screen...
  2. G_Dennis_Finn_vTGA
    Gingerbread Jul 19, 2018
    G_Dennis_Finn_vTGA , Jul 19, 2018 :
    Just one question for you.
    You want the pixel experience (I assume by you saying stock you don't mean "stock OnePlus" or "stock AOSP") why not but the pixel?
    imeyash likes this.
  3. prajnay0
    Ice Cream Sandwich Jul 19, 2018
    prajnay0 , Jul 19, 2018 :
    Marwadi_Rahul
    why oneplus why ?
    + give us an option to use something useful like Google feed instead of Shelf.... its a waste of prime space on Home screen...​
    the DP3 UI is really similar to the stock one I got the android P booted on my op5 and while comparing it. they are really similar but there is a difference in the icons and some changes and recents is heavily inspired from Google's own implementation so if you hate the UI you should blame Google
    arknu likes this.
  4. Marwadi_Rahul
    Froyo Jul 19, 2018
    no I don't want Pixel experience...
    if you look at Original Oxygen OS in OP3 with very close to Stock Nougat....it was amazing...
    and Its not a rant....I owned OP3 for almost 2 years and was a great device..but why we should not get the new Android P UI....
    argument like why don't buy Pixel don't make sense....
    imeyash likes this.
  5. Marwadi_Rahul
    Froyo Jul 19, 2018
    what ?
    you booted DP3 to OP5 ..
    man hats off to you..... no more comments now...
    not a satire but really admire your enthusiasm....[e]1f64f[/e]
  6. prajnay0
  7. prajnay0
    please do more research rather then jumping to conclusions
    imeyash likes this.
  8. G_Dennis_Finn_vTGA
    Marwadi_Rahul
    argument like why don't buy Pixel don't make sense....​
    the UI, both in Android P beta and OOS stable is very close to the Pixel (OOS stable is stock, as OnePlus since this is a OnePlus phone). there are differences, but look at Samsung or LG and you'll see OnePlus is very close to stock pixel. Even looking at a Motorola it's pretty close, both OnePlus and Motorola tweak some things but keeps pretty close to the Pixel experience (as much as Google will let them anyway).
    What specifically do you want in the Android P beta UI? From what I see most is either straight from our inspired by Google.
  9. abogrhen
    Eclair Jul 19, 2018
    abogrhen , Jul 19, 2018 :
    Normal update from beta2 to beta3
    Did not work for me
    After the update process it send me to the recovery
    And keep rebooting
    Wipeing cashe and system
    Sent me back to wiped beta2
    Only solution was to wipe everything
    Then i got to beta3
    I have both op and pixels navbar options
    unlike what I have read in here
    imeyash and wleonardocruz like this.
  10. Shashank M Suresh
    Froyo Jul 19, 2018
    Shashank M Suresh , Jul 19, 2018 :
    okay. can anyone check if safetynet passes and can we use payment apps like Tez or BHIM ? If not then did flashing magisk fix it?
    ravidevani likes this.
  11. peter osoro
    Donut Jul 19, 2018
    peter osoro , Jul 19, 2018 :
    I can't install the DP3, I did this;
    1.Tried on OOS 5.1.9 and I get "system update failed",wiping and installing in vain
    2.Downgraded to 5.1.8 still couldn't install DP3 or DP2
    3.Flashed TWRP on 5.1.8 and still I couldn't glash the DP2 or DP3 with TWRP(kdownloderoperation execute error)
    4.Got bricked and unbricked using Qualcomm download tool and OOS 5.1.5
    5.Tried installing DP3 & DP2 on 5.1.5 in vain
    6.Updated to 5.1.8 via OTA and still couldn't install either of the DPs
    And now I'm upgrading to OOS 5.1.9 until someone figures out what's wrong.
    Disclaimer: All OOS zips flash without any error.
    1.DP3
    2.DP2
  12. Mandeep_Aulakh
    Cupcake Jul 19, 2018
    Mandeep_Aulakh , Jul 19, 2018 :
    thnx buddy!!
    imeyash likes this.
  13. TheMysticalShaman
    Honeycomb Jul 19, 2018
    TheMysticalShaman , Jul 19, 2018 :
    Since Android Pistachio is being released late August, early September... Just a little over a month from now. Wouldn't be wise just to wait that short period of time for the stable full version of Android Pistachio?
    imeyash likes this.
  14. peter osoro
    Donut Jul 19, 2018
    I'm facing the same issue
    and I can verify checksums of the downloaded zips.
  15. prajnay0
    it does not pass safety net
  16. pmoar3
    Froyo Jul 19, 2018
    pmoar3 , Jul 19, 2018 :
    bug- signal is quite week and reliance Jio is dropping volte quite often ? anyone facing the same issue ?
    will switching Jio sim to slot 1 make any difference?
  17. Shashank M Suresh
    Froyo Jul 19, 2018
  18. prajnay0
    yup, that might be the reason of safety net not working
  19. Shashank M Suresh
    Froyo Jul 19, 2018
  20. FaleshC
    KitKat Jul 19, 2018
    FaleshC , Jul 19, 2018 :
    nope, this dev preview doesn't have safety net profile certification.
    so magisk or not it won't pass safety net.
