236
Android P Beta Developer Preview 3 for OnePlus 6
  1. jaivaghela
    Ice Cream Sandwich Jul 19, 2018
    jaivaghela , Jul 19, 2018 :
    Problem with phone calls, when I'm on a call and somebody else is trying to call me the phone sometimes just switches to the other call and puts the other on hold or ends the call, quite irritating and I have to call back.
  2. raghunathtosh
    Cupcake Jul 19, 2018
    raghunathtosh , Jul 19, 2018 :
    try to go to bootloader mode from switch off ...from there you can go to recovery mode..
  3. overpricedcoffee
    Honeycomb Jul 19, 2018
    overpricedcoffee , Jul 19, 2018 :
    Have you followed the guide for rolling back to 5.1.x?
  4. G_Robert_Rodriguez_gEoG
    Eclair Jul 19, 2018
    G_Robert_Rodriguez_gEoG , Jul 19, 2018 :
    In my instance, face unlock is working flawless again. Since 5.1.8 my screen lock would take a second then unlock. I did notice that while horizontal the pull down screen is about half the size of the screen.
  5. JeevantSah
    JeevantSah , Jul 19, 2018 :
    In my instance, face unlock is working flawless again. Since 5.1.8 my screen lock would take a second then unlock. I did notice that while horizontal the pull down screen is about half the size of the screen.​
    may be i should install the whole zip again for face unlock
    for horizontal i was talking about this(it only happens when display is set to small):
  6. [email protected]
    Froyo Jul 19, 2018
  7. DasTapan
    Gingerbread Jul 19, 2018
    DasTapan , Jul 19, 2018 :
    no , phone is working good. so I'm thinking not to downgrade.
    no data also lost,is this unusual. because in flashing guide it is written there will be data loss. so backup was advised.
  8. G_Robert_Rodriguez_gEoG
    Eclair Jul 19, 2018
    I tried to install as well and the app crashes. [e]1f614[/e]
  9. DasTapan
    is OEM unlocking and usb debugging required to go to recovery mode.
  10. G_Robert_Rodriguez_gEoG
    Eclair Jul 19, 2018
  11. JeevantSah
    ohh sry for misunderstanding
  12. OnePlus_8t
    Jelly Bean Jul 19, 2018
    OnePlus_8t , Jul 19, 2018 :
    2 issues
    1- I have this app ( CpuFloat ) for CPU temp and frequency , I used to put in the status bar , in this build it appears under the status bar.
    2- apps folders in file manager disappear , sometimes they reappear but with 0 contenant
  13. yesh_rim
  14. OnePlus_8t
  15. Callme_Bi3
    Froyo Jul 19, 2018
  16. UCFour
    Donut Jul 19, 2018
    UCFour , Jul 19, 2018 :
    no
  17. JoseReyes69
    JoseReyes69 , Jul 19, 2018 :
    After doing some research, it seems to be a known issue due to Samsung app not being compatible.
  18. premsonu118
    Froyo Jul 19, 2018
    premsonu118 , Jul 19, 2018 :
    Hello everyone.. I want to need Android P for OnePlus 6 so If I downgrade back again it?
  19. G_Robert_Rodriguez_gEoG
    Eclair Jul 19, 2018
  20. G_Robert_Rodriguez_gEoG
    Eclair Jul 19, 2018
    Sucks but I usually don't keep my s3 paired to my phone. So I'll stay on dp3
