236
Android P Beta Developer Preview 3 for OnePlus 6
  1. C1529301356171
    Cupcake Jul 19, 2018
  2. Schrotty40
    Honeycomb Jul 19, 2018
    Schrotty40 , Jul 19, 2018 :
    I am on 5.1.9 with twrp and magisk. whene i install P with oneplus update, lost i twrp and root and also all data on my phone?
  3. preeteshkhivesara
    preeteshkhivesara , Jul 19, 2018 :
    but I'm already on the beta version .. will I have to wipe everything?
  4. jack_839
    jack_839 , Jul 19, 2018 :
    G_Robert_Rodriguez_gEoG
    It randomly works right.​
    try display size small and font also small and then remove navigation bar....then try landscape and also try to swipe from left or right insteed of middle. Plzz check and report.
  5. Nhas81
    Eclair Jul 19, 2018
    Nhas81 , Jul 19, 2018 :
    buenos chicos. ¿Podrían ayudarme a llegar a Oreo? Tendría que desbloquear el bogood guys Could you help me get down to Oreo? I would have to unlock the bootloader
  6. yesh_rim
  7. G_Robert_Rodriguez_gEoG
    Eclair Jul 19, 2018
    G_Robert_Rodriguez_gEoG , Jul 19, 2018 :
    I do have it set to small and when pulled down from either side it does throw it off center. When pulled down from the middle it is aligned.
    jack_839 likes this.
  8. Nhas81
    Eclair Jul 19, 2018
    Friends I'm in dp3 and I'd like to go back to Oreo. It is necessary to unlock the bootloader?
  9. yesh_rim
  10. daxmax1337
    Donut Jul 19, 2018
  11. G_Rich_Cowan_EQlj
    Gingerbread Jul 19, 2018
  12. F_Lakshmi_Pathi_yDIs
    F_Lakshmi_Pathi_yDIs , Jul 19, 2018 :
    same issue faced erase all your data during recovery ,then mine is ok now
  13. 4sheesh
  14. HarryRag
    HarryRag , Jul 19, 2018 :
    If you add the folder location to your PATH, adb works from everywhere :)
    So no need to put them in System32 folder.
  15. taiyou94
    Froyo Jul 19, 2018
  16. Krisso
    Krisso , Jul 19, 2018 :
    [QUOTE =“yesh_rim,post:18843021,member:1607869”] [ATTACH = full] 822721 [/ ATTACH]
    如何在Android P Beta更新後使通話電話應用程序無法正常工作[/ QUOTE]
    [QUOTE =“yesh_rim,post:18842958,member:1607869”] Android p beta更新後手機無法正常工作[/ QUOTE]清除儲存空間
  17. manan_batish
    manan_batish , Jul 19, 2018 :
    1) There is still issue in fingerprint adding again after deleting
    2 )Phone app crashes again and again
    can be used as daily driver
    but have to give some time to adjust and if you can tolerate summer bugs
  18. manan_batish
    yes
  19. Arne Hermansen
  20. gino79
    gino79 , Jul 19, 2018 :
    I had a similar problem...Everytime I made a call, the phone app would close ending the call...ended up restoring phone back to factory (relock, 5.1.9).. .Then installed the modded Google dialer app just to try. ..then after a suggestion from someone on xda, I decided to redownload dp3, and dirty flashed with Google dialer still installed. .now I have zero call issues. ..made like 30 calls, and no issues.. .when b4 it was like every other call, there was a problem. ..
