236
Android P Beta Developer Preview 3 for OnePlus 6
  1. alexferdean
    Ice Cream Sandwich Jul 24, 2018
    alexferdean , Jul 24, 2018 :
    It does not actually delete the fingerprint. It still unlocks your phone. This issue has already been reported in this thread
    prashobhb likes this.
  2. Shashank M Suresh
    Froyo Jul 24, 2018
    Shashank M Suresh , Jul 24, 2018 :
    People were saying camera quality is good. but I didn't see any improvement. well for a beta very well built.
    And people who were complaining about safety net. Basic Integrity is still there. so no issues with payment apps or snapchat. Works without any flaws
  3. C1529301356171
    Cupcake Jul 24, 2018
  4. scuf
    scuf , Jul 24, 2018 :
    Seems almost stable. I would like to propose this due to its implementation on stock Android 9: Make the stock navbar gestures an option next to your own gestures. Thank you
    HackneyMan likes this.
  5. Hithesh3101999
    Donut Jul 24, 2018
  6. 7amdanxx
    Froyo Jul 24, 2018
  7. chrischow
    chrischow , Jul 24, 2018 :
    most problemsssssssss, just because most people don't read the install instruction carefully, and most people don't want to factory reset the device after update (yes, i'm one of these, but i have factory reset my device) ..........
    i saw some question repeat and repeat ask for help, but why you don't try factor reset the device???
    if you reset the device still have these problem, you can post here and tell OnePlus, cause these is "BETA" version, and they want to know any problems on this beta version, they need to solve.....
  8. youranimesh
  9. G_Roman_Krešne_tDXb
    Froyo Jul 24, 2018
    G_Roman_Krešne_tDXb , Jul 24, 2018 :
    I believe fist roll out should be with no extra fancy feature just fix camera animations and make it smooth after that you should start impelenting some tweeks from oxygen OS becouse i already see that in October/November there will be lots of issues just becouse of unfinished small things which will be very annoying
  10. Ramesha Y
  11. Deactivated User
    Jul 24, 2018
  12. G_Dennis_Finn_vTGA
    Gingerbread Jul 24, 2018
    G_Dennis_Finn_vTGA , Jul 24, 2018 :
    What are you going on about? This is a beta, and it's miles ahead of the past beta which is a month older. most if not all bug fixes and OnePlus enhancements will be in place by release, which will likely be November or December. This is sort of the whole reason for betas, to find and fix the small annoying unfinished things and bugs.
    Probably because you either A) didn't factory reset or B) restored from a back up. Read some of the thread, your food is in there.
    Then the beta isn't for you. If you can't understand how to move a file you shouldn't be messing with something that can cause your phone to break if you mess up.
    No, and if you don't know the difference between root and beta, maybe researching is what you need to be doing.
    jarei and limafranco like this.
  13. Mohit makhija1234
    Froyo Jul 24, 2018
    Mohit makhija1234 , Jul 24, 2018 :
    guys I have a doubt please help me
    Google pixel android P beta is on developer preview 4 which is a beta 3 previously when it was on dp 3 which is a beta 2
    since OnePlus android P beta is dp3 which means it is a beta 2 but lots of article from different web and videos on YouTube say OnePlus p beta 3 which means dp4 but it's dp3
    so it is dp3 beta 2 or dp4 beta 3
    lots of confusion please clear it up ..
  14. Horizon21000
    Honeycomb Jul 24, 2018
    Horizon21000 , Jul 24, 2018 :
    OnePlus didn't choosed a good name for their Preview.
    Oxygen Android P DP3 is based on Google Android P DP4!
  15. sud_p1
    sud_p1 , Jul 24, 2018 :
    Android P DP3 is better OR OOS 5.1.9?
    I'm currently using the Android P DP3 and as considering its a beta, its doing good.
    should i roll back to 5.1.9?
  16. PratikKawade
    Eclair Jul 24, 2018
    PratikKawade , Jul 24, 2018 :
    One plus camera
  17. Shashank M Suresh
    Froyo Jul 24, 2018
    Stability = OOS 5.1.9
    Get early access to new features = P
    Now don't ask which one to choose. you decide it.
  18. PratikKawade
    Eclair Jul 24, 2018
    You Should wipe the data , After wipping the stock dialler works
  19. sud_p1
    Thanks buddy. I just wanted to know is the battery life and performance better on P as compared to OOS 5.1.9
  20. Mohit makhija1234
    Froyo Jul 24, 2018
    ohh ..I get it... thanks buddy
