236
Android P Beta Developer Preview 3 for OnePlus 6
  1. avibored
    Honeycomb Jul 27, 2018
    avibored , Jul 27, 2018 :
    It didn't work for me I removed and added my face and that solved it
  2. Majuran thas
    Majuran thas , Jul 27, 2018 :
    English is just a language not knowledge my dear friend.
  3. innocent_pwn
    Cupcake Jul 27, 2018
  4. TonioLA
    Ice Cream Sandwich Jul 27, 2018
  5. GiuCam79
    Froyo Jul 27, 2018
    GiuCam79 , Jul 27, 2018 :
    Read open page... will found istructions
  6. Aditya Kumar Tiwari
    Eclair Jul 28, 2018
    Aditya Kumar Tiwari , Jul 28, 2018 :
    i reinstall OS .PIP only working with Whatsapp And not with other apps like GOOGLE DUO,YOUTUBE And Chrome.I m not able to transfer data by OP switch with My OP3.
  7. G_Dennis_Finn_vTGA
    Gingerbread Jul 28, 2018
    G_Dennis_Finn_vTGA , Jul 28, 2018 :
    Something is wrong with what your doing, everyone else has PIP, so my troubleshooting should say it's something specific to your phone, and the most likely cause is user error.
    Download update from top post.
    Move to to directory
    Update through settings.
    Boot to recovery.
    Wipe all data, factory reset.
    Boot into Android.
    Set up as new device.
    This should make it work, remember this is a beta, bugs are to be expected, but not starting fresh can cause excessive bugs to appear.
    OPToxic likes this.
  8. alexferdean
    Ice Cream Sandwich Jul 28, 2018
  9. Joffy_Jose
    Honeycomb Jul 28, 2018
    Joffy_Jose , Jul 28, 2018 :
    i have found a bug . we cant delete a fingerprint after its added. even though if we remove the fingerprint it still can be accessed.
    edit:-
    sorry for the duplicate error reporting. i haven't got the time to read the entire thread.!!
    emad khalid likes this.
  10. G_Dennis_Finn_vTGA
    Yep, it's only been mentioned about 25 times. Have you put it in the big tracker?
    Joffy_Jose likes this.
  11. Sathish_Bharathi
    Sathish_Bharathi , Jul 28, 2018 :
    Any one please help me to solve an phone (contact close)
    And oxygen launcher crashing problem.
    Is there any ota update available?
  12. _Loucif_Redjai_
    _Loucif_Redjai_ , Jul 28, 2018 :
    try to clear cache of the both applications .it'll works
    Sathish_Bharathi likes this.
  13. Sathish_Bharathi
    I have already tried so many times but still nothing happened.
  14. _Loucif_Redjai_
    u cleared the cache and data of the dialer and launcher via play store '?
  15. faizan_ahmad xyz
  16. Horizon21000
    Horizon21000 , Jul 28, 2018 :
    It starts to get a knowledge if you see someone just connect randomly vocabulary together and not even bother to check in Google Translate or a similar tool if it makes any sense at all.
  17. Horizon21000
    Did you set up your phone as a new device?
    Aditya Kumar Tiwari likes this.
  18. Horizon21000
    Why for gods sake, you don't make a factory reset?
  19. Aditya Kumar Tiwari
    Eclair Jul 28, 2018
  20. Horizon21000
    Yes it have but the camera app is still more buggy than the one from Oxygen 5.1.9 !
    alexferdean likes this.
