129
Android P Beta DP2 for OnePlus 6
  1. L1530888940553 Cupcake Jul 8, 2018
    L1530888940553, Jul 8, 2018 :
    Hello guys..I have bought my 1st one plus device recently. Except me, does anyone else is facing some camera issue related to sharpness?
    I am not able to get sharp images in closer or macro shots, which I used to get from my older cheap phone. If anyone is aware of this issue, please let me know about any update or how to fix the issue. Thanks
  2. hotmomma Ice Cream Sandwich Jul 8, 2018
    hotmomma, Jul 8, 2018 :
    I hope they fix Bluetooth streaming, widevine L1 support and the safetynet certification in this one and well maybe add pixel like gestures bc even the oppos and Xiaomis have those
    F1531140134204 likes this.
  3. idkwhoiam322 Marshmallow Jul 8, 2018
    idkwhoiam322, Jul 8, 2018 :
    Check with the app by jrummy. This one hasn't been updated since Jan 2017 and doesn't work well.
  4. Tom_Com_01 Gingerbread Jul 8, 2018
  5. hotmomma Ice Cream Sandwich Jul 8, 2018
    what do you expect after this??
  6. idkwhoiam322 Marshmallow Jul 8, 2018
  7. hotmomma Ice Cream Sandwich Jul 8, 2018
    nope, and I think they are because these are dependent onGoogle APIs
  8. ashwin6004 Honeycomb Jul 8, 2018
    ashwin6004, Jul 8, 2018 :
    ok now you tell me, what are major changes in UI elements for OOS (Oreo) when compared to OOS (Noughat) ??? Im also an OOS user from Android Marshmallow, and i didnt see any major UI changes atpeast from Noughat to Oreo. And now in P, i agreed there are some changes in UI and animations, and i would like to see more refreshing or a completely overhauled Oos in P!
  9. E1508089410008 Cupcake Jul 8, 2018
  10. G_arun_muthu_fnjf Eclair Jul 8, 2018
  11. Tom_Com_01 Gingerbread Jul 8, 2018
  12. ashwin6004 Honeycomb Jul 8, 2018
  13. ani150101 Froyo Jul 8, 2018
  14. ani150101 Froyo Jul 8, 2018
    ani150101, Jul 8, 2018 :
    also try to disable the camera app which will restore it to it's factory version and then re enable it.. and let me know if that works for u
  15. avila.sebas96 Cupcake Jul 8, 2018
  16. Winsten Cupcake Jul 8, 2018
    Winsten, Jul 8, 2018 :
    Bad af, 60 fps looks like 30 fps.
  17. G_Dennis_Finn_vTGA Gingerbread Jul 8, 2018
    G_Dennis_Finn_vTGA, Jul 8, 2018 :
    Does anyone know what AI is? Saying add AI is like saying add "stuff that makes my phone sound cooler", it means nothing without saying what exactly you want the AI to do.
    Do you want it to recognize scenes in the camera and split the best settings?
    Do you want it to know your charging habits and charge to 80% until just before you usually take the phone if the charger, then charge to 100%?
    Do you want the AI to rise up and take over the world?
    I have the term AI as used by people today, Artificial Intelligence, not cool stuff my phone could do.
  18. Horizon21000 Honeycomb Jul 8, 2018
    Horizon21000, Jul 8, 2018 :
    I think the term "AI" is miss used by the marketing of many manufacturers. If they speak about "AI" they mean basically a "machine learning" feature!
    You don't need an AI to make the gras greener in a picture!
  19. cponandroid Cupcake Jul 9, 2018
    cponandroid, Jul 9, 2018 :
    I've followed the instructions to flush the DP2.
    However, after performing step 7, the device fails to boot to OS (it just shows the red circle with two little white circles spinning around it).
    I can't rollback either, as per instructions - I need to boot to OS first.
    Any ideas for what shall I do next?
  20. sebfar Ice Cream Sandwich Jul 9, 2018
