129
Android P Beta DP2 for OnePlus 6
  1. cponandroid Cupcake Jul 9, 2018
    cponandroid, Jul 9, 2018 :
    Yes, however, the recovery mode's options are slightly different from what is written in instructions.
    Instructions say:
    6. Select Wipe data/factory reset, click power, select yes, confirm.
    On my device I've had:
    [Wipe data and cache / Advanced / Exit] -> selected Wipe data and cache
    [Reset system setting / Wipe cache / Erase everything(Music, pics, etc)] -> selected Reset system setting
    which presented the "System data & Cache will be reset, continue?" prompt -> selected Yes
    after a second received "Wipe success" message, and tapped Reboot.​
    wleonardocruz likes this.
  2. chazey2 Ice Cream Sandwich Jul 9, 2018
    chazey2, Jul 9, 2018 :
    Try pressing power and volume down to boot into recovery choose your language and choose erase everything, then reboot.
    cponandroid likes this.
  3. Tom_Com_01 Gingerbread Jul 9, 2018
    Tom_Com_01, Jul 9, 2018 :
    But it has already installed the beta recovery? So there won't be any language selection etc.
  4. Tom_Com_01 Gingerbread Jul 9, 2018
  5. Horizon21000 Honeycomb Jul 10, 2018
    Horizon21000, Jul 10, 2018 :
    What are you talking about?
    There is a stock recovery (Oneplus) and a custom recovery (like TWRP).
    You still on the stock recovery and you just need to go in it and make a factory reset, then the bootloop will be gone!
  6. Tom_Com_01 Gingerbread Jul 10, 2018
  7. cponandroid Cupcake Jul 10, 2018
    cponandroid, Jul 10, 2018 :
    This is it! Thanks a lot for the suggestion!
  8. Winsten Cupcake Jul 10, 2018
  9. Tom_Com_01 Gingerbread Jul 10, 2018
  10. Hardcore Froyo Jul 11, 2018
    Hardcore, Jul 11, 2018 :
    Just received my OP6, and installed the P preview using the method described above, this unlock the bootloader?
    Thks in advance!
  11. FaleshC Jelly Bean Jul 11, 2018
    FaleshC, Jul 11, 2018 :
    nope. you remember unlocking it?
  12. thegreatv Froyo Jul 11, 2018
    thegreatv, Jul 11, 2018 :
    Anyone having issues (force closing) with Instagram and Facebook apps on DP2 here?
    Hardcore likes this.
  13. hotmomma Ice Cream Sandwich Jul 11, 2018
    hotmomma, Jul 11, 2018 :
    nope
  14. MarkoBatrac Gingerbread Jul 11, 2018
  15. sebfar Ice Cream Sandwich Jul 11, 2018
    MarkoBatrac likes this.
  16. hotmomma Ice Cream Sandwich Jul 11, 2018
    Battery is great not excellent , very fluid , smooth & sick animations or transitions but Bluetooth streaming isn't available atm you can take calls tho
  17. F_Mili_Sarkar_qYjz Cupcake Jul 11, 2018
  18. I1530465425556 Cupcake Jul 11, 2018
  19. sebfar Ice Cream Sandwich Jul 11, 2018
    sebfar, Jul 11, 2018 :
    I'm using this version as daily driver. I don't have any nbig problem
    Predict23 likes this.
  20. F_Rakesh_Roshan_Rana_QCK Honeycomb Jul 11, 2018
