android position settings
  1. wzard70
    Cupcake Sep 26, 2018
    wzard70 , Sep 26, 2018 :
    After updating to oxygen 9 I can't find the position settings in the menu. How can I be sure my GPS is not always on?
  2. Vikingbear
  3. wzard70
    Yes, but this way I can only enable or disable position services. I'd like to have them on, but only via WiFi/LTE (low energy consumption). In the previous menu there was a specific option for that.
  4. jesu_raj_
    S1527789222437 likes this.
  5. Adityatawade17
    Honeycomb Sep 26, 2018
    Adityatawade17 , Sep 26, 2018 :
    What ! You Can't Do this in this Universe !
  6. jesu_raj_
  7. jesu_raj_
    jesu_raj_ , Sep 26, 2018 :
    I updated my one plus 6 to Android 9.0 and storage is slight increase d. so I checked on storage and viewed that system shows9.8 gb allocated.. is it possible to reduce that
  8. Adityatawade17
    No Sir, You Can't
  9. huwred
    huwred , Sep 26, 2018 :
    look under Google services and preferences
