555
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. JayFBuck
    Cupcake May 14, 2019
    JayFBuck , May 14, 2019 :
    Yeah, tried that multiple times. Same result every time. Didn't work. Sahara connection failed.
  2. ironass
    KitKat May 14, 2019
    ironass , May 14, 2019 :
    As per post #1 of this thread... this is not an official OTA update but merely an early Developers Preview of the basics of Android Q. It is not intended for daily use as lots of features and apps will not work.
    Sun90, drl431 and Kytharsis like this.
  3. M1557866479577
    M1557866479577 , May 14, 2019 :
    Been testing the beta as my daily for a few days. Did not have a single crash. As I prefer OxygenOS over stock Android I went back today.
    No problem whatsoever installing both the beta and the rollback using only the phone. All of you that haven't a clue what you're doing, stay away, it's as simple as that.
    Really looking forward to receiving the OxygenOS version of Android Q when it is done.
  4. P1527361100672
    Eclair May 14, 2019
  5. Kytharsis
    Marshmallow May 14, 2019
    Kytharsis , May 14, 2019 :
    This is a developer preview, not a beta.
    Sun90, zoran81, drl431 and 1 other person like this.
  6. ironass
    KitKat May 14, 2019
    This is NOT an Open Beta update. It is merely a very early and rough Developers Preview of Android Q that will be coming to the OnePlus 6/6T as an Open Beta OTA in about 6 months. This is not intended for daily use as most features are either not present or do not work. Flash it at your own RISK!
    Sun90, zoran81, drl431 and 3 others like this.
  7. Jeremy_Vincent
    Froyo May 15, 2019
    AdikartaDasa, zoran81 and ironass like this.
  8. kapilesh8
    Cupcake May 15, 2019
    kapilesh8 , May 15, 2019 :
    1. Загрузите последний ZIP-пакет обновления ROM с указанного сервера.
    2. Скопируйте пакет обновления ПЗУ в память телефона.
    3. Перейдите в Настройки -> Система -> Обновления системы -> Щелкните значок справа вверху -> Локальное обновление -> Нажмите на соответствующий установочный пакет -> Обновление -> Обновление системы завершено до 100%.
    4. После завершения обновления нажмите «Перезагрузить».
    5. Телефон загрузится в режиме восстановления для форматирования пользовательских данных, после форматирования снова перезагрузится.
    6. Обновление прошло успешно.
  9. Hebbnag
    Gingerbread May 15, 2019
  10. Greenforty
    Honeycomb May 15, 2019
    Greenforty , May 15, 2019 :
    Haven't really had any issues with the new Android Q gestures since setting a different launcher. only issue is in landscape mode where it sometimes thinks the middle of your screen is the edge. The gestures are intuitive, and the back swipe works well most of the time.
    Greenforty
    You can enable the new gestures from adb via the following commands.
    How to enable fully gestural navigation:
    adb shell cmd overlay enable com.android.internal.systemui.navbar.gestural
    How to disable fully gestural navigation:
    adb shell cmd overlay disable com.android.internal.systemui.navbar.gestural
    How to enable 2-button navigation:
    adb shell cmd overlay enable com.android.internal.systemui.navbar.twobutton
    How to disable 2-button navigation:
    adb shell cmd overlay disable com.android.internal.systemui.navbar.twobutton
    How to enable 3-button navigation:
    adb shell cmd overlay enable com.android.internal.systemui.navbar.threebutton
    How to disable 3-button navigation:
    adb shell cmd overlay disable com.android.internal.systemui.navbar.threebutton
    tested, and is working although sometimes it can be a bit buggy. Picking a launcher other than OnePlus launcher fixed most of the issues for me.​
  11. Easwaramurthy
    Easwaramurthy , May 15, 2019 :
    is it worth for installation?
  12. Greenforty
    Easwaramurthy
    is it worth for installation?​
    Android Q preview is very unstable, with apps not working or crashing, no fast charging, no fingerprint, chance to loose all your data and other issues, like sometimes the alarm doesn't work. I would therefore not recommend you install it on your main device. You should only install this preview if you want to check out some of the Android Q features. I would recommend waiting for a later version of the preview that might be more stable and usable.
    Kytharsis and Sun90 like this.
  13. Kanji Kher
    Donut May 15, 2019
    Kanji Kher , May 15, 2019 :
    i am oneplus 6t stable version now i am going to beta version how to flash guide please..
    one more thing i have not unlock bootloader so i have flash beta version or not ?
  14. Gurudutt Adke
    Eclair May 15, 2019
    Gurudutt Adke , May 15, 2019 :
    how's the Q beta been for the one plus 6 ?? how's the experience ?? any change in UI? in Q or any additional features?? please respond with ss if possible
  15. Neddard
    Lollipop May 15, 2019
    Neddard , May 15, 2019 :
    It's not a beta. It's a developer preview. Maybe it would qualify as an alpha, or as a beta of a beta. It's not meant to be used as a daily driver. It's meant to provide developers with an opportunity to see what they need to do to get their apps ready for Q.
    Think and read carefully before installing this thing. All the info is in the first page of posts of this thread.
    ironass likes this.
  16. FR_IFTEKHAR_ARIF_
    FR_IFTEKHAR_ARIF_ , May 15, 2019 :
    I have downloaded updates setup but after installation counter lot of issue to deformed my phone ..
    1.USB doesn't work properly.
    2.Ambient Display issue
    3.Screen Mode
    4.Smoothness also view point while this phone known as it's Speed.
    5.Some applications doesn't work,even not installed.
    6.Screen quality performance.
  17. Kanji Kher
    Donut May 15, 2019
  18. FR_IFTEKHAR_ARIF_
  19. ironass
    KitKat May 15, 2019
  20. chazey2
    Jelly Bean May 15, 2019
    chazey2 , May 15, 2019 :
    106 pages here nearly all the same old comments and you don't have an answer from it?
    Alexa75 and ironass like this.
