546
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. ironass
    KitKat May 25, 2019
    ironass , May 25, 2019 :
    What is your current firmware version?
    Settings > About phone > OxygenOS version
    Kytharsis likes this.
  2. Sai Adiraju
    Eclair May 25, 2019
    Sai Adiraju , May 25, 2019 :
    BETA 18
  3. Leon.861
    Froyo May 25, 2019
    Leon.861 , May 25, 2019 :
    just follow every instruction step by step
  4. wleonardocruz
    Gingerbread May 25, 2019
    wleonardocruz , May 25, 2019 :
    If this screen shot appear after install, maybe you skip erase all in recovery mode, else maybe you don't have enough space!
    if really you want this firmware you need make all the step one by one in first page!
  5. ironass
    KitKat May 25, 2019
    drl431, Kytharsis and wleonardocruz like this.
  6. Sai Adiraju
    Eclair May 25, 2019
  7. wleonardocruz
    You need have the stable version of Android 9, before try the DP of Android 10.
  8. ironass
    KitKat May 25, 2019
    LMAO
    I knew you'd say that! :D
  9. ironass
    KitKat May 25, 2019
    Or, an earlier Open Beta than 18 or 10.
    drl431 and Kytharsis like this.
  10. wleonardocruz
    ironass
    Or, an earlier Open Beta than 18 or 10.​
    All of this guy don't read and don't want investigate nothing, and fail quickly.
    want everything easy,
    drl431, Kytharsis and ironass like this.
  11. Z1541253414554
    Cupcake May 25, 2019
    Z1541253414554 , May 25, 2019 :
    Hi,
    I have face some issue in speaker only one speaker giving sound second one not give. it problem is common because my another friend facing same problem.
  12. Dresa91
    Android Q May 25, 2019
    Dresa91 , May 25, 2019 :
    there is only one speaker...
    drl431 and ironass like this.
  13. Kytharsis
    Marshmallow May 25, 2019
    Kytharsis , May 25, 2019 :
    Already told him. He posted the same thing in the 9.0.5/13 thread.
    drl431, ironass and Dresa91 like this.
  14. ironass
    KitKat May 25, 2019
    In that case... he's had it in stereo from both of you now... which is more than the phone speaker will give him. ;)
    1uk3, Kytharsis, drl431 and 1 other person like this.
  15. Dresa91
    absolutely:D thanks, you made my evening:D
    Kytharsis, drl431 and ironass like this.
  16. zedkay
    Gingerbread May 26, 2019
    zedkay , May 26, 2019 :
    I had the same error. I unlocked the bootloader and flashed this preview with TWRP.
  17. zedkay
    install it with twrp
  18. phil42600
    Cupcake May 26, 2019
  19. kouzelnik3
    Froyo May 26, 2019
    kouzelnik3 , May 26, 2019 :
    Hi, I want ask if there is a function that should be presented in Android Q - if I launch two apps simultaneously into split screen, do they run both or does one of them stop meanwhile the other run is running (like it is presented in the previous versions of Android)? Tag me within the answer, please
  20. ironass
    KitKat May 26, 2019
    phil42600 likes this.
