520
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. MattiaMlg Eclair Jun 14, 2019
    MattiaMlg, Jun 14, 2019 :
    can you send me privately? I can't find it
  2. jaygatsby9909 Honeycomb Jun 14, 2019
  3. MattiaMlg Eclair Jun 14, 2019
  4. jaygatsby9909 Honeycomb Jun 14, 2019
    jaygatsby9909, Jun 14, 2019 :
    I guess you'll just have to look for it. Or use the search function like most people. If you're having this much trouble finding the post then I don't know that you should really be installing it anyway.
  5. MattiaMlg Eclair Jun 14, 2019
    "Looks like I was right. It's up."
    ok, but where I can download it?
  6. jaygatsby9909 Honeycomb Jun 14, 2019
    I gave you the link. Just so you know, since you clearly don't, you need to open that link in Chrome. Once again I must urge you, that since you're having this much trouble clicking on a link, I don't think that you should probably be downloading a developer beta. I would highly recommend that you stay on stable.
  7. MattiaMlg Eclair Jun 14, 2019
  8. jaygatsby9909 Honeycomb Jun 14, 2019
  9. cristian.raduca Cupcake Jun 14, 2019
    cristian.raduca, Jun 14, 2019 :
    Hi guys. Might be already discussed, but I did not find it here. I get an error when trying to update. I am on latest beta on Android Pie. Any suggestions?
  10. cristian.raduca Cupcake Jun 14, 2019
  11. jaygatsby9909 Honeycomb Jun 14, 2019
    cristian.raduca
    Hi guys. Might be already discussed, but I did not find it here. I get an error when trying to update. I am on latest beta on Android Pie. Any suggestions?​
    Roll back to stable then update. It has been discussed here a few times already.
    cristian.raduca likes this.
  12. cristian.raduca Cupcake Jun 14, 2019
  13. cristian.raduca Cupcake Jun 14, 2019
  14. Kytharsis Marshmallow Jun 14, 2019
    Kytharsis, Jun 14, 2019 :
    No. Stick to the non-DP builds if this is important to you.
    AdikartaDasa likes this.
  15. cristian.raduca Cupcake Jun 14, 2019
    I did not say it is important. it was a curiosity. thanks
  16. jaygatsby9909 Honeycomb Jun 14, 2019
    I wonder if it would make any difference if we used lawn chair or Nova launcher? Would it get rid of the launcher issues?
    Drewgaren likes this.
  17. jaygatsby9909 Honeycomb Jun 15, 2019
    jaygatsby9909, Jun 15, 2019 :
    I'm also wondering if updating to a newer camera build from apkmirror or a GCam mod would fix the camera issues.
  18. S1527958166239 Donut Jun 15, 2019
    S1527958166239, Jun 15, 2019 :
    why showing this?
    I am unable to install Android Q.
    I am pie beta user, I am already up to date.
    please any one tell the correct reason or installation procedure.
  19. jaygatsby9909 Honeycomb Jun 15, 2019
    Roll back to stable
    S1527958166239 likes this.
  20. S1527958166239 Donut Jun 15, 2019
