520
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. jaygatsby9909 Honeycomb Jun 15, 2019
  2. S1527958166239 Donut Jun 15, 2019
  3. jaygatsby9909 Honeycomb Jun 15, 2019
    jaygatsby9909, Jun 15, 2019 :
    It's in the original post. Just go to the top and download it.
  4. cristian.raduca Cupcake Jun 15, 2019
    cristian.raduca, Jun 15, 2019 :
    Also, face recognition is not included, if there is anyone who finds this necessary. Just in case someone reads the thread before the installation of the OS.
    Still, I have another question for those who have installed it: does your fingerprint unlock works? For me, it takes the screen to sleep.
    iDrewn likes this.
  5. Robin Cain Cupcake Jun 16, 2019
  6. ironass KitKat Jun 16, 2019
  7. BapRx Cupcake Jun 16, 2019
    BapRx, Jun 16, 2019 :
    OnePlus 6t here, the fingerprint works well on the lockscreen, however it does not work within applications (Dashlane, Cryptomator, Banking apps, etc.)
  8. BapRx Cupcake Jun 16, 2019
  9. ironass KitKat Jun 16, 2019
    ironass, Jun 16, 2019 :
    You are replying to me... I don't have an issue. :D
  10. pmoar3 Froyo Jun 17, 2019
    pmoar3, Jun 17, 2019 :
    if you dont know the basics ,please don't try It may leave you without any option to get it full functional.
    WiFi stability and network stability is prime things that are not good enough .
    btw to install it you need to get to previous version probably released in April May .
    that will work as they worked for me .
    the best thing you can do is to downgrade using the zip provided and then install dp2
  11. sfksuperman Honeycomb Jun 17, 2019
  12. phil42600 Cupcake Jun 17, 2019
  13. sfksuperman Honeycomb Jun 17, 2019
  14. phil42600 Cupcake Jun 17, 2019
    phil42600, Jun 17, 2019 :
    works very well with local upgrade. but with twrp i don't know.
  15. sfksuperman Honeycomb Jun 17, 2019
    sfksuperman, Jun 17, 2019 :
    DP to MP rollback guide - via Local OTA update
    Note: This upgrade method will erase all the contents of the phone, please be sure to backup first.
    1. Download the latest ROM upgrade zip package from the specified server.
    2. Copy the Rollback package to the phone storage.
    3. Go to Settings -> System -> System Updates -> Click top right icon -> Local upgrade -> Click on the corresponding installation package -> upgrade -> System upgrade completed to 100%.
    4. After the upgrade is complete, click Restart.
    5. Phone will boot into recovery mode to format user data, it will reboot again after formatting.
    6. Update successful.​
    does this above method works when i try to go to stable version from beta version for op6T?
  16. sfksuperman Honeycomb Jun 17, 2019
    okay. and since it's downgrade, then the stable os zip is different from normal stable os zip, right?
  17. phil42600 Cupcake Jun 17, 2019
    6t i don't know
  18. phil42600 Cupcake Jun 17, 2019
    yes[e]1f609[/e]
  19. sfksuperman Honeycomb Jun 17, 2019
    do you any thread for op6T beta to stable downgrade?
  20. phil42600 Cupcake Jun 17, 2019
    sorry no.
