553
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. Z1560110775588
    Donut Sep 2, 2019
  2. sutanshu
    Gingerbread Sep 2, 2019
    Z1560110775588 likes this.
  3. Z1560110775588
    Donut Sep 2, 2019
    Z1560110775588 , Sep 2, 2019 :
    ok sir thank you so what file do i have to download
  4. Chumdini
    Chumdini , Sep 2, 2019 :
    none right. ow because the current update is newer than the preview.
  5. Z1560110775588
    Donut Sep 2, 2019
    so ill have to wait
  6. Chumdini
    correct. there is a rumor that on September 3, Google will release Android ten to the pixels and then it should come fairly quickly to 1+
  7. Z1560110775588
    Donut Sep 2, 2019
    alright sir thank you
    Chumdini likes this.
  8. sutanshu
    sutanshu , Sep 2, 2019 :
    List
    If you have stable version 9.0.16 then update to beta
    if you have already on beta then Go to 1st page DP3
    download downgrade file & install (data will full wiped)
    After that you will run on stable 9.0.4 older version
    Now 9.0.4 stable is older version you want update to higher version stable & beta or DP3 you can do it (not 100% sure)
  9. sanjay_reddy_
    Cupcake Sep 3, 2019
    sanjay_reddy_ , Sep 3, 2019 :
  10. Pranav Tyagi
    Eclair Sep 4, 2019
  11. Ching_Nam_Ip
    Gingerbread Sep 4, 2019
    Ching_Nam_Ip , Sep 4, 2019 :
    no dp4 already
  12. muugee
  13. p51d007
    KitKat Sep 4, 2019
    p51d007 , Sep 4, 2019 :
    Well, I played around with the release version on my old PH-1 Essential. If you tap hold on the "easter egg" it rotates things around. LOL, I made this one by moving the 1, where it said 10 around
    Almost perfect circle with a line "forbidden" "not wanted" type logo.
  14. HoOdy_Rohan
    Cupcake Sep 4, 2019
    HoOdy_Rohan , Sep 4, 2019 :
    Hey man...just wanna know that....the latest build that u are using...is it stable enough to try out n does the user data the internal memory.... gets wiped??
  15. ironass
    KitKat Sep 4, 2019
    ironass , Sep 4, 2019 :
    This is not the latest build, which is Developer Preview 3 and has been abandoned by OnePlus in favour of the imminent launch of Android 10 Open Beta.
    Kytharsis likes this.
  16. p51d007
    KitKat Sep 5, 2019
    p51d007 , Sep 5, 2019 :
    I did the OTA official. The PH-1 I have was 100% stock. Only tweak was developer mode enabled.
    Never touched any of my data. The only thing I changed after the update was to set it back to the 3 buttons on the home screen. I don't care for the "pill" button.
  17. Naveen_t
    Cupcake Sep 8, 2019
    Naveen_t , Sep 8, 2019 :
    was not able to install the DP, error "system update installation failed". I am on oxygen os 9.0.8
  18. Kytharsis
    Marshmallow Sep 8, 2019
    Kytharsis , Sep 8, 2019 :
    Wait for the 10 beta to come out later this month.
    Lupastro82 and drl431 like this.
  19. Y1550400572257
    Cupcake Sep 12, 2019
  20. manideep6656
