559
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. mvjunkie
    Cupcake Sep 27, 2019
    mvjunkie , Sep 27, 2019 :
    I downloaded the DP zip twice, every time I goto local upgrade and click the DP zip I get installation failed instantly. I am currently on the latest beta build. Anyone know why I can't install the DP build?
  2. NodePoint
    Gingerbread Sep 27, 2019
    NodePoint , via OnePlus 6T Midnight Black , Sep 27, 2019 :
    mvjunkie
    I downloaded the DP zip twice, every time I goto local upgrade and click the DP zip I get installation failed instantly. I am currently on the latest beta build. Anyone know why I can't install the DP build?​
    The latest open beta build is newer than the latest developer preview build. What you're encountering from the sounds of it is downgrade protection (just in case something goes very wrong).
    Kytharsis likes this.
  3. G_jwal_patel_xLHB
    Cupcake Sep 30, 2019
    G_jwal_patel_xLHB , Sep 30, 2019 :
    Same here its downloading the file but there is error in update
  4. Kytharsis
    Nougat Sep 30, 2019
    Kytharsis , Sep 30, 2019 :
    Don't use this build.
    G_jwal_patel_xLHB and drl431 like this.
  5. meinonA
    Cupcake Oct 1, 2019
    meinonA , via OnePlus 6T , Oct 1, 2019 :
    heey guys, it was said 3 months ago that this download isn't a good one to use as a daily driver.
    what are your thoughts now? Is it stable enough to use it as a daily driver compared to the pie beta (which I now use as daily driver)? any recommendations on what download I should use?
  6. NodePoint
    Gingerbread Oct 2, 2019
    NodePoint , via OnePlus 6T Midnight Black , Oct 2, 2019 :
    I recommend waiting for the Android 10 Open Beta. This developer preview is nowhere close to being daily driver. The upcoming Android 10 Open Beta release should be way more suitable.. just don't expect it to be as daily driver ready as Pie beta (there will be bugs).
  7. F1534382035201
    Cupcake Oct 4, 2019
  8. Kytharsis
    Nougat Oct 4, 2019
    Kytharsis , Oct 4, 2019 :
    No. Android 10 isn't available yet.
  9. DUS5TY
    Cupcake Oct 5, 2019
    DUS5TY , Oct 5, 2019 :
    Unlock boot loader root install twrp
    download dp3 install it from twrp
    Wipe factory wipe chache
    Restart u have dp3 installed
    But with some glitches
    It looks grate
  10. Gameslayer
    Gingerbread Oct 6, 2019
    Gameslayer , Oct 6, 2019 :
    hi team,
    is it safe to use Bhim or any you transection applications in Beta build ??
  11. Gameslayer
    unable to update getting following error currently using latest Beta of oxygen is beta 17
  12. drl431
    Marshmallow Oct 6, 2019
  13. Gameslayer
    I am trying to install android q that's it bro
  14. drl431
    drl431 , Oct 6, 2019 :
    Wait for the first open beta.
  15. Gameslayer
    drl431 likes this.
  16. mabinoguion
    Cupcake Oct 8, 2019
  17. drl431
    Marshmallow Oct 8, 2019
    drl431 , Oct 8, 2019 :
    Nope, but maybe late this month or early next month. OP might make an announcement on Oct. 10.
    Kytharsis, mabinoguion and ironass like this.
  18. Barmenchik
    Froyo Oct 8, 2019
  19. doncarlodc likes this.
