562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. Haverholm
    Honeycomb May 8, 2019
    Haverholm , May 8, 2019 :
    So.. I'm trying to roll back to Android P, but the updater keeps telling me to Move installation package into root directory. When upgrading to Android Q, I just put the .zip-file in the Android-folder, and the updater found it there. Where do I need to put it now?
  2. gaster
    Moderator Moderator May 8, 2019
    gaster , May 8, 2019 :
    Wow. You are all surprises Manu. Thank you for this great and fast job!
    B_Wrath likes this.
  3. Vishnuram_Jatin
    Eclair May 8, 2019
  4. Saidinho84
    Gingerbread May 8, 2019
    Saidinho84 , May 8, 2019 :
    follow the steps in the first post. Download the roll back file in the link at the first post in this topic and follow the steps
    ironass and Artemus like this.
  5. Vishnuram_Jatin
    Eclair May 8, 2019
    Vishnuram_Jatin , May 8, 2019 :
    there is no face unlock and fingerprint not yet working
  6. Ronakkar
    Ronakkar , May 8, 2019 :
    guy download the roll back from pie build it is working for me link https://downloadmirror.co/32Uv/OnePlus6Oxygen_22_OTA_015_all_1808102118_downgrade_68586451f7334c4d.zip?pt=O0tYEv19ouZb2uwLZOS44WEYDR1USi%2BWUzQZsyvHPFU%3D
  7. G_Suvrajyoti_karmakar_wr
    Cupcake May 8, 2019
    pharrellt likes this.
  8. pharrellt
    Froyo May 8, 2019
  9. treskinze
    Eclair May 8, 2019
    treskinze , May 8, 2019 :
    download the full downgrade, and then put it on your local folder (root folder) remove the pin..then install it. after installation. boot to recovery and wipe data. make sure to make a back up becuse it will erase all the items in storage
  10. Artemus
    Community Hero 2020 May 8, 2019
    Artemus , May 8, 2019 :
    Remove the ".jar" from the filename... Don't know why they made it a jar file to begin with.
  11. Msv_Vamsi
    Msv_Vamsi , May 8, 2019 :
    I tried it .....but not working bro
  12. Jomarxd
    Cupcake May 8, 2019
    Jomarxd , May 8, 2019 :
    Has someone been able to perform the downgrade ??? this beta version is very unstable, worse if they put blocking by PIN, when you restart it, it tells you that it is incorrect.
    amulya134a likes this.
  13. zoran81
    Jelly Bean May 8, 2019
    zoran81 , May 8, 2019 :
    Into the root directory, as it said
  14. Artemus
    To everyone complaining that the rollback file isn't working, you have to remove the ".jar" from the filename in order for it to work. The Java compiler used to generate it more than likely is the cause of this and is a simple fix.
    Can someone pin this please?
  15. G_Bilal_rajput_yJRs
    Cupcake May 8, 2019
  16. G_Suvrajyoti_karmakar_wr
    Cupcake May 8, 2019
    G_Suvrajyoti_karmakar_wr , May 8, 2019 :
    thanks this worked but now I am getting the below error.
  17. Artemus
    The developer preview JUST got announced. It'll be a few months till anyone knows if legacy devices will get it. Be patient.
  18. Jomarxd
    Cupcake May 8, 2019
    Delete the .jar, that only remains in .zip, let me know if you can do the downgrade, because I can not find the OEM, in order to do it
  19. A1524848742676
    Cupcake May 8, 2019
  20. Msv_Vamsi
    even then it didn't work
