562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. yesh_rim
    Cupcake May 8, 2019
  2. Jomarxd
    Cupcake May 8, 2019
    Jomarxd , May 8, 2019 :
    I have to try it, because until now, I'm trying it with another ROM that I was not using the support of the web
  3. djhixson88
    Donut May 8, 2019
    djhixson88 , May 8, 2019 :
    I did that too:/ didn't work
  4. Benjamin Birken
    Cupcake May 8, 2019
    Benjamin Birken , May 8, 2019 :
    Habe mir das Download für Android Q runtergeladen und installiert. Bin nicht zufrieden mit der Steuerung und der Benutzeroberfläche.
    Daraufhin habe ich die Beta-Version für Android 9 runtergeladen und im Dateimanager umgeschoben, wie zuvor auch schon. Nur leider findet das System das Update nicht. Was kann ich nun tun?
  5. W1554009467464
    Cupcake May 8, 2019
    W1554009467464 , May 8, 2019 :
    can we use this beta version or not? someone told me that do not download beta version coz it's not good so please suggest me
  6. Benjamin Birken
    Cupcake May 8, 2019
    I am trying too, its not working
  7. Vishnuram_Jatin
    Eclair May 8, 2019
  8. Laki Shetty
    Honeycomb May 8, 2019
    Laki Shetty , May 8, 2019 :
    Whomever flashed q rom. Please post some pics where you find differences against pie based oxygen rom.
  9. Msv_Vamsi
    Gingerbread May 8, 2019
    Msv_Vamsi , May 8, 2019 :
    hmm....same here [e]1f60f[/e]
  10. TheAyushJain
    TheAyushJain , May 8, 2019 :
    OnePlus' proprietary solution is better than Android Q's MIUI-esque gesture. PERIOD
  11. Jomarxd
    Cupcake May 8, 2019
  12. PrakarshX
    Ice Cream Sandwich May 8, 2019
    PrakarshX , May 8, 2019 :
    shut up and kys. right now. nothing Google makes can EVER be compared to MIUI. Also, it's basically the same thing what OP and Google are doing except in Google's you have a line at the bottom on which you can swipe to switch apps.
    Beautiful
  13. Moin2200
    KitKat May 8, 2019
    Moin2200 , May 8, 2019 :
    Oh is there issues with the rollback package?
  14. TheAyushJain
    That side swiping back gesture is going to interfere with hamburger menu in tons of apps , so either google has to change their gesture navigation or those tons of apps have to update , and redesigning those apps is practically not possible
    IMO , Oneplus' own navigation is better than other gesture navigation
    Also , watch XDA's video on android Q beta 3 , you'll get a better idea
  15. Benjamin Birken
    Cupcake May 8, 2019
  16. PrakarshX
    ik how it works you can swipe from the right side my boy. hamburger is on the left.
  17. ironass
    Lollipop May 8, 2019
    ironass , May 8, 2019 :
    Strange... it has worked for 1,000's of other users.
    Are you using the correct downgrade package for your model of phone from post #1 of this thread?
    Have you moved the downgrade package to the root directory of your phone... not in a file?
    Have you removed... .jar from the end of the file name so that it ends in .zip with no full stop/period after it?
  18. djhixson88
    Donut May 8, 2019
    Yes to all. It's not a big deal I'm up and running. I just found it odd.
  19. TheAyushJain
    Oneplus should provide all the 3 types of navigation options (Proprietary, Q's , and classic button) in settings as they did for Android Pie , to keep everyone happy
  20. Msv_Vamsi
