562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. Waingro1926
    Cupcake May 8, 2019
    Waingro1926 , May 8, 2019 :
    How did you roll back exactly? I've been trying for two hours, now phone got stuck to bootlogo...
  2. L1555762905203
    Cupcake May 8, 2019
    L1555762905203 , May 8, 2019 :
    this release is completely unstable .. I'm unable to use face unlocking feature and few apps not working properly..
  3. ironass
    Lollipop May 8, 2019
    ironass , May 8, 2019 :
    How's that working out for you then? ;)
    Sun90 likes this.
  4. mahatoamar2013
    Cupcake May 8, 2019
  5. L1555762905203
    Cupcake May 8, 2019
    download the pie version, copy to root then upgrade with local option
  6. Waingro1926
    Cupcake May 8, 2019
    I'd do that but my phone is not responding, stuck in bootlogo and won't turn off or on. Any advice please?
  7. reath123
    Gingerbread May 8, 2019
    reath123 , May 8, 2019 :
    Is it mandatory to wipe date to upgrade from opt 17 to Android Q DP??
  8. Waingro1926
    Cupcake May 8, 2019
  9. Ronakkar
    Ronakkar , May 8, 2019 :
    factory reset your phone
  10. dg23awsz
    Cupcake May 8, 2019
  11. Jomarxd
    Cupcake May 8, 2019
  12. Waingro1926
    Cupcake May 8, 2019
    Can't do, phone seems to be bricked in the start animation.
  13. Jomarxd
    Cupcake May 8, 2019
  14. amulya134a
    Cupcake May 8, 2019
    amulya134a , May 8, 2019 :
    yeah done that! its up now. Thanks
  15. ironass
    Well... it looks as though @Manu J. warning in post #1 of this thread is working really well...
    "As the name suggests, this build of Android Q is best suited for developers and early adopters. As it is still in an early stage of development. That said, we do not recommend flashing this ROM if you have little to no experience in software development or flashing custom ROMs. Proceed at your own RISK!"
    Lots of people are now discovering that they are in fact, not developers, early adopters and have no experience in software development or flashing custom ROMs. They are also not good at reading and searching this thread for answers.
    TOP TIP: 1,000's of people have already downgraded successfully back to Android Pie by using the correct downgrade package from post #1 and placing it in the root directory/system storage, (not in a file), of the phone and removing the, ".jar", extension and then flashing it through Local Upgrade. If, for any reason it is not working for you... go back and re-read and re-check everything, twice.
  16. 8484858567
    Eclair May 8, 2019
    8484858567 , May 8, 2019 :
    Can we hide the three buttons from below ?
  17. Waingro1926
    Cupcake May 8, 2019
  18. AleCarreraSP
    Cupcake May 8, 2019
  19. amulya134a
    Cupcake May 8, 2019
    Waingro1926
    Can't do, phone seems to be bricked in the start animation.​
    just press volume up and power button for 10 secs. it will reboot and then it will say 10 more tries will erase ur data. just do that and ur phone will be up after factory reset
  20. PrakarshX
    Ice Cream Sandwich May 8, 2019
    PrakarshX , May 8, 2019 :
    I think I got one of the mainline updates because my battery percentage is now showing.
    8484818184 likes this.
