562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. 8484858567
    Eclair May 8, 2019
    amulya134a likes this.
  2. Waingro1926
    Cupcake May 8, 2019
    Waingro1926 , May 8, 2019 :
    It won't load the recovery menu, in fact it won't do anything! It is stuck to the boot logo and it won't respond
  3. amulya134a
    Cupcake May 8, 2019
    amulya134a , May 8, 2019 :
    just press volume up and power button for 10 secs. it will reboot and then it will say 10 more tries will erase ur data. just do that and ur phone will be up after factory reset
  4. 8484858567
    Eclair May 8, 2019
    8484858567 , May 8, 2019 :
    Can you help how you are able to view that ? any changes need to be done ?
  5. PrakarshX
    Ice Cream Sandwich May 8, 2019
    PrakarshX , May 8, 2019 :
    it's gone again, I guess it was a bug of a bug. idk :/
  6. Waingro1926
    Cupcake May 8, 2019
    Thanks man
  7. amulya134a
    Cupcake May 8, 2019
    just press volume up and power button for 10 secs. it will reboot and then it will say 10 more tries will erase ur data. just do that and ur phone will be up after factory reset.
    ironass likes this.
  8. amulya134a
    Cupcake May 8, 2019
    Its a major bug though. They have a different encryption method and we all are restoring back our settings from cloud. That's where its causing this problem for many people. Just remove any passkeys from boot once ur phone is up
  9. elampumpkin
    Froyo May 8, 2019
    elampumpkin , May 8, 2019 :
    Guys if you have set a pin, DO NOT REBOOT YOUR DEVICE. The encryption isn't working as of right now...
    If you are stuck, factory reset your device with the bootloader menu
    ironass and amulya134a like this.
  10. G1554642785398
    Cupcake May 8, 2019
    G1554642785398 , May 8, 2019 :
    i just update it. my all pics and video lost and totally wrost update i think Android pie is best then Android Q. if i can use again pie then suggest me how i can do it.how can i recover my pics.In Android Q we cant find lot of funtion can it be added or not tell me about it. Can i use Android pie again if yes tell me how. if u can recover my pics then its so usefull for me. please resolve my problem.
    C1545726448329 likes this.
  11. Pankkajarora
    Gingerbread May 8, 2019
    Pankkajarora , May 8, 2019 :
    yes because the extension you're getting is .zip.jar
    remove the .jar from the Downloaded package, it will work.
  12. Iamrohit.07
    Honeycomb May 8, 2019
    Iamrohit.07 , May 8, 2019 :
    This Beta is just an uncooked food which is definitely not even tasty. better don't put this on the menu. This is not good. literally have nothing to explore. please optimise it then release no user has too urgency to use highly unstable beta.
    Thank you.
    No offence.
  13. Iamrohit.07
    Thank you.
    No offence.
  14. Pankkajarora
    yes, because the extension you're getting is .zip.jar
  15. kamblineeraj
    Cupcake May 8, 2019
    kamblineeraj , May 8, 2019 :
    some one please help me as I've lost my pictures. please tell me there is a way to retrieve them :(
  16. kamblineeraj
    Cupcake May 8, 2019
    same here. please help me if you find a way.
  17. Pankkajarora
    there is no way to retrieve them unless you have enabled the backup option in your Google photos application.
    if that too not enabled then really sorry to say!! You need to forget about the lost data of yours.
  18. H1528104995325
    Cupcake May 8, 2019
  19. MilanMoradia
    Froyo May 8, 2019
    MilanMoradia , May 8, 2019 :
    who says navigation gestures are buttery smooth in android q for oneplus? infect there is no option to change on screen nav. buttons as of now. so dont expect too much for this update . but after 2 or 3 update no one can beat oneplus os.
    elampumpkin likes this.
  20. elampumpkin
    Froyo May 8, 2019
    It was clearly mentioned that the data would be wiped. The local upgrade also warned the user before proceeding. This is an early beta, so things will be rough
    amulya134a and AleCarreraSP like this.
