562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. SpasilliumNexus
    Froyo May 8, 2019
    SpasilliumNexus , May 8, 2019 :
    LOL. Reading is hard. Bye bye pics. The OP stated that you would lose everything on the phone and to back up everything. Not their problem.
  2. Moin2200
    KitKat May 8, 2019
    Moin2200 , May 8, 2019 :
    Allright I'll update my post with this new information.
  3. desaidigvijay0
    Cupcake May 8, 2019
    desaidigvijay0 , May 8, 2019 :
    There are many bugs in the beta version.
    1) The Adaptive brightness doesn't work
    2) Fingerprint Authentication doesn't work
    3) The User Interface of Notifications is not properly Aligned
    4) As said portrait mode is not working
    5) The UI of settings menu is also not aligned properly
    so far these are the bugs I found.
  4. nicovfernando
    Froyo May 8, 2019
    nicovfernando , May 8, 2019 :
    Hey bud, it's cleay stated what version this release is all about. this is not a "Beta" release but a Developer Preview release.
    zoran81 likes this.
  5. elampumpkin
    Froyo May 8, 2019
    elampumpkin , May 8, 2019 :
    If you had Google backup switched on, you can find all the pics in google photos
  6. titom444dj
    Donut May 8, 2019
    titom444dj , May 8, 2019 :
    for nav bar I've paid and use vivid. N G who is fully customizable. like op will never let you customize.
    for people saying it's not good enough to be released. it's precised.
    personally I've really appreciate to being able to test it today already. i prefer to find solutions and see evolutions.
    for themes. I've only see google photo auto adapting his theme for the moment.
    ho and Netflix doesn't work.
    amulya134a likes this.
  7. ironass
    Lollipop May 8, 2019
    ironass , May 8, 2019 :
    Hands up those that didn't follow the instructions in @Manu J. post #1, about backing up everything before flashing...
    Unless you made a backup or synced your stuff, it is gone I am afraid. :(
    Neddard and zoran81 like this.
  8. nicovfernando
    Froyo May 8, 2019
  9. kamblineeraj
    Cupcake May 8, 2019
  10. nicovfernando
    Froyo May 8, 2019
    check if the file name is .zip file.
  11. kamblineeraj
    Cupcake May 8, 2019
    kamblineeraj , May 8, 2019 :
    the link posted in the 1st post isn't opening. any other way?
  12. Pankkajarora
    Gingerbread May 8, 2019
    Pankkajarora , May 8, 2019 :
    those who are unable to download the rollback build via the given link at the beginning of the post.
    please look at the extreme top right corner after clicking the link "open in browser or open with browser"
    you'll be able to download the rollback or developer preview build.
  13. Pankkajarora
    I would recommend people not to try this build because of the following reasons:
    1. it's a developer preview, not a beta build
    2. fingerprint scanner,
    3. face unlocking,
    4. camera portrait mode
    5. Ambient display
    6. Night mode (too much yellow)
    7. signal strength
    8. wifi strength
    9. encryption not enabled.
    10. DO NOT CHARGE YOUR PHONE AFTER POWER OFF THE DEVICE.
    11. DO NOT ENABLE PIN OR PASSWORD OPTION WHILE SETTING UP YOUR PHONE.
    12. to rollback to the stable build please remove the .jar extension from the downloaded package.
    13. if you are using dual sim then you'll be irritated because of setup notifications
    few are above-known issues.
    happy flashing and I've rolled back to the previous stable build of Android after facing major issues with the developer preview.
  14. rutvikkoyani
    Cupcake May 8, 2019
    rutvikkoyani , May 8, 2019 :
    on installing package ,it is showing that you can't install a lower package than current system
    im.san likes this.
  15. Pawan_Harwar
    Froyo May 8, 2019
  16. Sathish_Bharathi
    Sathish_Bharathi , May 8, 2019 :
    all of you just rename the recovery download file as only.zip
    remove the .jar
    I will work perfectly.
    for go back Android 9.0
  17. pharrellt
    Froyo May 8, 2019
    pharrellt , May 8, 2019 :
    there is no button but when I search for.it I appears but there are no button ;( su I'm stuck nice that 7 is on the way ;)))
  18. Goldi Rajput
    Cupcake May 8, 2019
  19. Pankkajarora
    just enable the USB debugging and go back to the root folder.
    1. remove the .jar from the downloaded file, keep it until filename.zip
    2. now go to a system update
    3. click on local storage
    4. now you should be able to see the file.
    install updates and you're good to go.
    thanks!!
  20. X1509185521678
    X1509185521678 , May 8, 2019 :
    Benjamin Birken
    Habe mir das Download für Android Q runtergeladen und installiert. Bin nicht zufrieden mit der Steuerung und der Benutzeroberfläche.
    Daraufhin habe ich die Beta-Version für Android 9 runtergeladen und im Dateimanager umgeschoben, wie zuvor auch schon. Nur leider findet das System das Update nicht. Was kann ich nun tun?
    hast du TWRP? würde dir empfehlen, es damit zu versuchen.
    wenn du kein TWRP hast bin ich leider auch überfragt
    edit: 1 tipp gäbe es noch, schau dass die Endung deiner Datei auch auf .zip lautet, und wenn nicht dann benenne sie so
