562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. pharrellt
    Froyo May 8, 2019
    pharrellt , May 8, 2019 :
    ;( doest work
  2. X1509185521678
    Gingerbread May 8, 2019
    X1509185521678 , May 8, 2019 :
    too late I guess, next time use Titanium Backup or similar to save your datas before installing a new operating system
  3. X1509185521678
    get all-in-one tool from xda forum. helped me a lot with such issues
  4. Trevor.Hawkes
    Ice Cream Sandwich May 8, 2019
    Trevor.Hawkes , May 8, 2019 :
    The idiots who have jumped into this mess without knowing what they are doing indicate that nothing should be put up for general release until it is without many problems.
    We have seen it all along on the Beta threads and the Stables aren't much better sometimes.
    "When will my 1+?? Get the update"
    "Why haven't I got the update"
    "How do I download it"
    "It doesn't work, fix it"
    "How do I rollback"
    "This crappy up date will force me to buy a ???? next time never again OnePlus"
    ade0410 and zoran81 like this.
  5. M1557330568072
    Cupcake May 8, 2019
    M1557330568072 , May 8, 2019 :
    Hi,
    This is not ok rom for OnePlus6T.
    apps dont work, light on display is too low, gms signal crashes...
    I tryed to make downgrade to last stock rom but I can not install it.
    Message is "you can not install older rom".
    What can I do now to back official stock rom?
  6. Pankkajarora
    pharrellt likes this.
  7. Pankkajarora
    Pankkajarora , May 8, 2019 :
    press volume UP + Power on button
    get into recovery mode and wipe and clean data.
    next time make sure you don't enable the PIN or Password option. live with the pattern.
  8. Yugam padha 02
    Donut May 8, 2019
  9. M1557330568072
    Cupcake May 8, 2019
  10. Muthukumar7
    Froyo May 8, 2019
    Muthukumar7 , May 8, 2019 :
    clear .jar from the file
    Yugam padha 02 likes this.
  11. SanDaDdiO
    Eclair May 8, 2019
    SanDaDdiO , May 8, 2019 :
    yes please read the WARNING in full. definitely not a daily driver. had to flash back after a couple hours of testing.
    ** Update **
    The issue was after i flashed the beta it was sluggish and there wasnt any network data connection so i did a reboot my 6T and then it went into the PIN required. When i put in my PIN that was set before reboot. SO i had to goto the recovery mode. Flash to Factory an reboot. at this point i set it up with no info and downloaded the fullwipe and put it in the root folder. after that i did a system update from local and it worked.
  12. M1557330568072
    Cupcake May 8, 2019
    im.san likes this.
  13. Professorjordan
    Froyo May 8, 2019
    Professorjordan , May 8, 2019 :
    I can't get mine to revert back,I can't get use on screen buttons.i says move to root folder.which I did but it can't find the file
  14. im.san
    Cupcake May 8, 2019
    im.san , May 8, 2019 :
    I'm getting the below error strangely... not sure if the download link for 6T got updated or something...a
    ny suggestions ??
  15. Professorjordan
    Froyo May 8, 2019
  16. Pankkajarora
    scroll up the page and you'll get the resolution.
    cheers!!
  17. Vigo0711
    Cupcake May 8, 2019
    Vigo0711 , May 8, 2019 :
    I forgot to back up my phone before this update and lost all my photos... How can i recover?
  18. Cervantes
    Moderator Moderator May 8, 2019
    Cervantes , May 8, 2019 :
    Hi
    The update or beta thread is a thread of questions and/or commentary
    Please, read the first, second, seventh post
    Thread merged
  19. XDan000
    Cupcake May 8, 2019
    XDan000 , May 8, 2019 :
    Need help! I installed AndroidQ with success. however, when I downgraded with the provided zip, my 6t suddendly stop showing screen. When I connect to my pc it makes a connection sound but cantdo nothing! any help?
  20. ade0410
    ade0410 , May 8, 2019 :
    You can't.
