562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. XDan000
    Cupcake May 8, 2019
    XDan000 , May 8, 2019 :
    So, you did the Rollback without "permanent" black screen? How?
  2. G_Gabriel_Larios_IqVl
    Cupcake May 8, 2019
    G_Gabriel_Larios_IqVl , May 8, 2019 :
    Did you get anyhelp with this mine is doing the same thing HELP
  3. beingrahulag
    Gingerbread May 8, 2019
    beingrahulag , May 8, 2019 :
    OnePlus 6, when touching fingerprint sensor, phone is locking
  4. Pankkajarora
    Pankkajarora , May 8, 2019 :
    did you guys download the correct version of rollback build?
    hope you didn't download the OP6 build instead of OP6T or vice versa.
    rollback build given on the beginning of the post is absolutely working fine and one doesn't need to downgrade using adbfast or connecting via laptop..
    enable the developer options and enable debug using USB
    reboot the device once
    locate the zip file to the root (remove the .jar from the file)
    install updates
    you're good with the stable build.
  5. mrgray
    mrgray , May 8, 2019 :
    When could we expect a stable Android Q for the 6T? obviously not expecting an exact date but just wanted to know an approximation.
  6. Kaiken
    Donut May 8, 2019
    Kaiken , May 8, 2019 :
    Shocking at the amount of people in here that don't read.
    For those that took the time to share your impressions, thank you!
    Looking forward to a more stable DP.
    Weeks to Months.
  7. XDan000
    Cupcake May 8, 2019
    I'm pretty sure I downloaded the right version of the rollback, but now I cant do nothing after it, literally have a black screen and i know my phone is turning on due to the windows sounds
  8. Chumdini
    Honeycomb May 8, 2019
    Chumdini , May 8, 2019 :
    here's my question. what'd some of y'all think was going to happen to your phones when OP explicitly said they don't recommend this unless you're a developer? were you guys expecting a BETA to be stable? if you won't take the time to read and research a bit, you don't deserve the help.
  9. Pankkajarora
    reboot a couple of more times and clean the cache via recovery mode.
    I did face the same problem but after a couple of tries it worked out for me.
  10. XDan000
    Cupcake May 8, 2019
    How could u go to recovery mode? I cant because my screen is just black
  11. KORRA SAI RAM NAIK
    Donut May 8, 2019
  12. Chumdini
    read through the thread ...you'll find your answer . if you were unsure of anything at all why install the beta anyways?
  13. Hermann_kao
    Cupcake May 8, 2019
    Hermann_kao , May 8, 2019 :
    Bonjour
    je viens d'installer la beta sur le OnePlus 6 (A6003)
    1-Les vibrations du clavier sont trop intenses
    2-Le mode portrait de la caméra faciale fonctionne
    3-Le pourcentage de batterie ne s'affiche pas dans la barre de batterie
    4-Le mode sombre se mixe parfois au mode claire
    5-Le réseau wifi n'est pas excellent mais fonctionne
    6-La charge rapide ne marche pas
    7-Le capteur d'empreintes ne fonctionne pas pour le déverrouillage de l'écran(L'écran s'eteint quand on pose le doigt sur le capteur)
    8-Le téléphone est lent
    9-Le réseau mobile balance excessivement
  14. KORRA SAI RAM NAIK
    Donut May 8, 2019
    KORRA SAI RAM NAIK , May 8, 2019 :
    actually the link is not opening
  15. Chumdini
    KORRA SAI RAM NAIK
    actually the link is not opening​
    u are on the beta if you're asking for the roll back . You need to read the thread before doing anything when it comes to betas. or don't use them at all if you aren't a developer.
  16. KORRA SAI RAM NAIK
    Donut May 8, 2019
    ok help me with roll back
  17. XDan000
    Cupcake May 8, 2019
  18. Chumdini
    plenty of people just like you who don't read have similar situations. all I'm saying is your answers have been asked multiple times .
  19. goanup
    Cupcake May 8, 2019
    goanup , May 8, 2019 :
    hi. I installed today for 6t
    never set pin or password for this update . I have set the pin and I stuck up in booting . wrong pin.
    then I hard rest the device ✓ clean all user data .
    it is working now.
    network doesn't shows VOlte. I am on Airtel.
    it shows LTE. and yes network connection not stable like in Pie.
    yes. camera app closed when you chose potrait mode.however you can click photos.
    have fun
  20. G_vatsal_pancholi_EDZQ
    Donut May 8, 2019
    G_vatsal_pancholi_EDZQ , May 8, 2019 :
    I just hope us one plus 5 users get android Q too. maybe too good to be true...
