562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. ryano891
    Honeycomb May 7, 2019
    ryano891 , May 7, 2019 :
    From the first page.. "Note: This upgrade method will erase all the contents of the phone, please be sure to backup first. "
    #81
    Bintang12 and sasiwinski like this.
  2. Terriniak
    Cupcake May 7, 2019
    Terriniak , May 7, 2019 :
    Not sure if this is just me but the in screen finger print reader is active all the time... can't hit the space bar well...
    #82
  3. Cheetosdust
    Junior Moderator Junior Moderator May 7, 2019
    Cheetosdust , May 7, 2019 :
    Oh dear lord. o_O
    Maybe your post should be pinned in case anyone is going to update especially to try the new gestures. I don't see it mentioned in the opening post.
    #83
  4. matthu.2711
    The Lab - OnePlus 7 Pro Reviewer May 7, 2019
    matthu.2711 , May 7, 2019 :
    For your case, check where you got the custom recovery from, downgrade to the stable Pie build and then to Q
    #84
  5. Stormy_Wolf
    Cupcake May 7, 2019
    #85
  6. pandoras_fox
    Cupcake May 7, 2019
    pandoras_fox , May 7, 2019 :
    Happening to me as well. Pretty annoying.
    I set the "must enter password" at startup and added a number into the password - and I can't input the number at boot, effectively locking me out of my phone after I rebooted once :/
    #86
  7. Some_Random_Username
    Community Bug Hunter May 7, 2019
    #87
  8. starfustymdd
    Cupcake May 7, 2019
    starfustymdd , May 7, 2019 :
    It says content, not contacts... Go ahead and read again
    #88
  9. SpasilliumNexus
    Froyo May 7, 2019
    SpasilliumNexus , May 7, 2019 :
    Aww. I'ma title you "The Little Cupcake That Thought He Could". It's okay buddy. You're still learning comprehension, and that's okay!
    Let me help you out by quoting OP:
    #89
  10. NateDev
    NateDev , May 7, 2019 :
    Yeah that would be good since as you said people are probably upgrading with the gestures as a main reason.
    Here's some pictures so unless the gestures are somewhere else (I searched and didn't see them either) or I'm just blind they're not there.
    #90
    guywong and kylesare57 like this.
  11. B1533324093077
    Cupcake May 7, 2019
    B1533324093077 , May 7, 2019 :
    no it doesn't but head genius
    #91
  12. Terriniak
    Cupcake May 7, 2019
    also can't flash back... going from beta 9 to q. tried and gives message about downgrade not allowed. going to try for beta 9 local. tried to go back to MP and no go.
    #92
  13. ironass
    Lollipop May 7, 2019
    ironass , May 7, 2019 :
    My thoughts ryano891...
    If you are just on a converted T-Mobile (USA) model it will not matter, except for encryption, etc: However, I do not think that Magisk, modules and TWRP custom recovery will be fully compatible just yet and a roll-back entails a full wipe of data and cache. At least there is now official roll-back firmwares now. :D
    #93
    ryano891 likes this.
  14. juniornunes
    Cupcake May 7, 2019
    juniornunes , May 7, 2019 :
    so i flashed it in twrp and it worked fine im gonna try magisk next
    flashing magisk in twrp doesnt work lol
    #94
    Xcutioner and ironass like this.
  15. Terriniak
    Cupcake May 7, 2019
    that failed too ... had any one downgraded successfully?
    #95
    Saumyata and machrm like this.
  16. NateDev
    testing right now
    #96
  17. matthu.2711
    #97
  18. G_Joey_Townsend_XlLn
    Cupcake May 7, 2019
    G_Joey_Townsend_XlLn , May 7, 2019 :
    Tried going back to BETA and got same message. Downloading MP now...I hope this gets figured out quickly because this Q beta was horrible =[
    #98
  19. ZMansour
    Donut May 7, 2019
    #99
  20. G_Flapjack47513
    Cupcake May 7, 2019
    G_Flapjack47513 , May 7, 2019 :
    Android Q feels weird in a bad and good way the only gestures you can use is the home and back button and multi task previews and the shelf isn't working and also the settings feels old
    FlixbusLennart, NateDev and ZMansour like this.
