562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. T1557270694434
    Cupcake May 8, 2019
    T1557270694434 , May 8, 2019 :
    me 2
    I couldn't find the system navigation.
    so sad.
    And the dark mode is grey dark.
    so i think it's based on beta 2.
    NateDev likes this.
  2. P1557251588110
    Cupcake May 8, 2019
    P1557251588110 , May 8, 2019 :
    I want to roll back on pie,but local update dosenot show anything,even though I move the file in the root directory.please help
  3. JuAnCaStRoP
    Gingerbread May 8, 2019
    JuAnCaStRoP , May 8, 2019 :
    I can't seem to get the navigation gestures to show up. they are non existent since there is no option.
    T1557270694434 likes this.
  4. treskinze
    Eclair May 8, 2019
    treskinze , May 8, 2019 :
    I'm currently on open beta 09 (6t) and i want to roll back to the official version, can i use the full downgrade to roll back? is it safe? thanks in advance.
  5. kayttaj909
    Cupcake May 8, 2019
    kayttaj909 , May 8, 2019 :
    My phone just froze and is refusing to force shut down. I've tried pressing every button combination for various amounts of time and nothing. any ideas?
    edit: nevermind, after 15 minutes it finally rebooted
  6. James.riley14
    Cupcake May 8, 2019
  7. kayttaj909
    Cupcake May 8, 2019
    for some reason the rollback image if downloaded with phone turns into a .zip.jar file. i downloaded it again with a computer and it then stayed as a .zip file and now the rollback works
    ironass likes this.
  8. G_samarth_singh_YHrL
    Donut May 8, 2019
    G_samarth_singh_YHrL , May 8, 2019 :
    Check page 5/6 similar case he got it fixed
  9. GCMarvin
    Cupcake May 8, 2019
    GCMarvin , May 8, 2019 :
    For some reason when downloaded, the file was renamed to *.zip.jar, you have to rename it to *.zip, then local update will find it.
  10. August0
    Cupcake May 8, 2019
    August0 , May 8, 2019 :
    There's not an Android q version in the Android studio emulator?
  11. James.riley14
    Cupcake May 8, 2019
    James.riley14 , May 8, 2019 :
    I am sure that would work if I could get into recovery
  12. ironass
    Lollipop May 8, 2019
    ironass , May 8, 2019 :
    See post #129, above.
  13. G_Flapjack47513
    Cupcake May 8, 2019
    G_Flapjack47513 , May 8, 2019 :
    Thank you this helped a lot
  14. G_samarth_singh_YHrL
    Donut May 8, 2019
    Well, it happened to me and the way i fixed it was by typing the password or anything multiple time. it takes times but it will shows that 10 trys are left and then it reset and you will need to setup again
  15. derLenno
    The Lab - OnePlus 6 Reviewer May 8, 2019
    derLenno , May 8, 2019 :
    You can not be serious.
  16. James.riley14
    Cupcake May 8, 2019
  17. treskinze
    Eclair May 8, 2019
  18. JeffGoldblum
    Cupcake May 8, 2019
    JeffGoldblum , May 8, 2019 :
    This is the solution!
  19. DVNK09
    DVNK09 , May 8, 2019 :
    Open in browser.
  20. Ben_Oakes_
    Cupcake May 8, 2019
    Ben_Oakes_ , May 8, 2019 :
    Hi guys, I see no one else has written a solution to rollback to android p. The issue was that the phone could not open the .jar file its been uploaded as on this site. To get around this, download the file onto a computer which will download as a zip file which you could transfer onto the phone via a USB.
    Cheers
