562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. JuAnCaStRoP
    Gingerbread May 8, 2019
  2. DVNK09
    DVNK09 , May 8, 2019 :
    Dude, read the entire post. At the very bottom it tells how to get back to Android Pie!
  3. saurabh2020
    Cupcake May 8, 2019
    saurabh2020 , May 8, 2019 :
    Android Q Beta is a big time mess, I was also facing the problem of PIN on startup and had to completely reset/erase my phone 3 times (same thing happened every time). Also the DASH charge is not working was charging so slow that accubattery was showing it to take 3.5 hours to charge upto 80%.
    I'm rolling back to Pie.
    NateDev and DVNK09 like this.
  4. Josiah1231
  5. DVNK09
    Believe so.
    Josiah1231 likes this.
  6. DVNK09
    Mentioned by many.
  7. treskinze
    Eclair May 8, 2019
    treskinze , May 8, 2019 :
    I'm currently on open beta 09 (6t) and i want to roll back to the official version, can i use the full downgrade to roll back? is it safe? thanks in advance.
  8. DVNK09
    They did not already. ◖⚆ᴥ⚆◗
    Silverloup likes this.
  9. NateDev
    Honeycomb May 8, 2019
    NateDev , May 8, 2019 :
    I just renamed it and removed .jar
  10. NateDev
    just rename it
  11. rollerk
    Eclair May 8, 2019
    rollerk , May 8, 2019 :
    OnePlus 6 the rollback package is not working.
    "System update installation failed"
    Any idea, how to get back to stable official Pie on OP6?
    Thanks.
  12. DVNK09
    I am pretty sure you can reset the phone, then try reinstalling and you may have luck.
  13. DVNK09
    Beta 09, is that the Pie or the new beta released today. if so, yes.
  14. Ze_Chickain
    Cupcake May 8, 2019
    Ze_Chickain , May 8, 2019 :
    Why there is not all the features from the Pixel devices? Navigation gestures, dark mode...
  15. pj2016
    Cupcake May 8, 2019
    pj2016 , May 8, 2019 :
    Unable to unlock OnePlus 6T after installing Android Q beta. I get “Wrong pin” message despite entering correct pin. Anybody know how to fix this?
  16. DVNK09
    This is the first preview...
    Ze_Chickain likes this.
  17. DVNK09
    A lot of people are saying this. I think you can reset your phone a couple times by going into the fastboot mode I believe and then eventually it'll let you in. I would roll back though.
  18. treskinze
    Eclair May 8, 2019
    open beta 09 for pie sir.
    DVNK09 likes this.
  19. anisite
    Cupcake May 8, 2019
  20. DVNK09
    If you want to go back to original Pie search the forums for the Pie beta for OnePlus 6 and download that roll back. I don't know for sure if this one is for that. It may be but I would go to the previous one to be safe. 09 caught me off guard. ▼・ᴥ・▼
