562
Android Q Beta (Developer Preview) for OnePlus 6/6T
  1. beingrahulag
    Gingerbread May 10, 2019
    beingrahulag , May 10, 2019 :
    bro, press power + volume up key at the same time to start the phone,
    you will go to bootloader
    from there read the switch combinations and go the wipe data page,
    wipe all the data one by one
    voila
    you will get your phone back
    and just to make sure this never happens
    put a pattern lock .
    jesusito. likes this.
  2. J0hnE
    Froyo May 10, 2019
    J0hnE , May 10, 2019 :
    First, you have to convert to the international version since you have the T-Mobile software installed. Search on XDA there's a thread that explains how to do it.
  3. M1557509390979
    Cupcake May 10, 2019
  4. OnePlus_8t
    Jelly Bean May 10, 2019
    OnePlus_8t , May 10, 2019 :
    i did install it , and it erased everything ( auto , after restarting )
  5. Shrijal Shrestha
  6. im_Sultan
  7. halloiod07
  8. kdngk
    Eclair May 10, 2019
    kdngk , May 10, 2019 :
    Hey guys,
    I just updated my OP6 software to Andriod Q, but I'm in trouble right now. I entered the security pin and fingerprints smoothly. But I restarted the phone and I entered the correct pin and it always shows "Wrong Pin". Is there any way to go back. :(
  9. ironass
    Lollipop May 10, 2019
    ironass , May 10, 2019 :
    Artemus. likes this.
  10. halloiod07
    halloiod07 , May 10, 2019 :
    if you have problem whit that the phone not find the zip file to go back to android pie you just have to give it a new name and not have the jar there
  11. halloiod07
    M1533840106071
    if you have problem whit that the phone not find the zip file to go back to android pie you just have to give it a new name and remove the . jar
    PS: the zip file link to download it is in the top of the android q beta post
  12. ironass
    The link is in post #1 of this forum as you would know if you had read post #7. :rolleyes:
    M1533840106071 likes this.
  13. TheMysticalShaman
    Honeycomb May 10, 2019
    TheMysticalShaman , May 10, 2019 :
    Not very functional. Lacking customization apps not working. Very few settings. I rolled back to Pie for full benefits. This build is absolute garbage.
    Om_Parikh likes this.
  14. halloiod07
    i know
  15. Artemus.
    Community Hero 2020 May 10, 2019
    Artemus. , May 10, 2019 :
    ... You didn't read the first post before delving in, did you?
    Griogarach, Loper_fan and ironass like this.
  16. Nnvelezm
    Eclair May 10, 2019
  17. G_Antoine_ISIDORE_JNme
  18. Artemus.
    ironass likes this.
  19. Artemus.
    This is why you read the thread.
    Alexa75 likes this.
  20. ironass
    Which phone version do you have... 6, 6T, McLaren, T-Mobile?
    Which downgrade package are you using?
    [EDIT] Drat! Ninja'd by Kytharsis... again! ;)
