Android Q Beta on T-Mobile 7 Pro
  1. Colinm428
    Gingerbread May 25, 2019
  2. toastytoast1234
    Marshmallow May 25, 2019
    toastytoast1234 , May 25, 2019 :
    If you can't work that out for yourself, you probably shouldn't even try.
    Would you know how to recover?
    ironass and Sargo like this.
  3. Colinm428
    Colinm428 , May 25, 2019 :
    yes I know how to flash builds I've done this many times. But sometimes it doesn't work if it's carrier locked. I'm not asking how to flash I'm asking if the T-Mobile one is eligible for the beta
    Joey Pardella likes this.
  4. KTaylor62
    Honeycomb Jun 4, 2019
    Joey Pardella and jallentech1 like this.
  5. Networkdood lives
    Eclair Jun 5, 2019
  6. Johanastan
    Donut Jul 17, 2019
    Johanastan , Jul 17, 2019 :
    But does that mess up your warranty?
  7. Networkdood lives
    Eclair Jul 17, 2019
  8. jlsmith929
    Cupcake Jul 19, 2019
    jlsmith929 , Jul 19, 2019 :
    not even that works anymore you will immediately run into hardware software doesn't match up issues which then turns into a complete mess having to flash everything back with the MSMTOOL
  9. Joey Pardella
    Gingerbread Jul 30, 2019
    Joey Pardella , Jul 30, 2019 :
    I was wondering this myself
  10. Joey Pardella
    so how do us T-Mobile op7pro people get to test out the android Q betas or developer previews???
  11. ironass
    KitKat Jul 30, 2019
    ironass , Jul 30, 2019 :
    The simple answer is... you don't. The eventual Android Q release controlled by T-Mobile (USA) will not be anything like the Android Q Developer Previews for the worldwide, global, model. Besides, as we have already seen, it takes 2-3 weeks for TMO to certify a firmware, so not much use on a monthly DP update that would have to be further converted each time to their spec's.
    Joey Pardella and H1561960043803 like this.
  12. Joey Pardella
    Gingerbread Aug 26, 2019
    Joey Pardella , Aug 26, 2019 :
    fail on my part, for getting the op7pro from T-Mobile! I learned my lesson!!! swear![e]1f62d[/e]
  13. weirdo911
    Eclair Sep 3, 2019
    weirdo911 , Sep 3, 2019 :
    I bought 6T from T-Mobile since they had $300 off. I got it unlocked and requested OnePlus for unlock code. Immediately I turned it into an international version.
    Now I'm enjoying faster updates.
  14. ironass
    KitKat Sep 3, 2019
    Racing24 likes this.
