77
Android Q Developer Preview 2 for OnePlus 6/6T
  1. yankygurk Donut Jun 17, 2019
  2. Q1527331062450 Eclair Jun 17, 2019
  3. bhushanvohra Cupcake Jun 17, 2019
    bhushanvohra, Jun 17, 2019 :
    my one plus launcher is stop working again and again true caller app not working how I can upgrade back to pie because it support only LTE network
  4. ApoorvVarma Cupcake Jun 17, 2019
    ApoorvVarma, Jun 17, 2019 :
    in android q OnePlus launcher is not working and now I am unable rollback to android pie, I downloaded the rollback package copy at root path same as I done for Android q but at local install no package is showing...
    help me to roll it back to android pie
  5. ApoorvVarma Cupcake Jun 17, 2019
    download nova launcher so atleast you are able use this beta version.. facing same issue and even unable to rollback to pie
    bhushanvohra likes this.
  6. G_Karothikeyan Honeycomb Jun 17, 2019
    G_Karothikeyan, Jun 17, 2019 :
    thanks @Manu J.
  7. Mithun_M_Shivaswamy Cupcake Jun 17, 2019
    Mithun_M_Shivaswamy, Jun 17, 2019 :
    these are few problems I found
    1. YouTube. it's getting self closed when I first time play a video. And has to be restarted again
    2. it's taking too long time for keyboard to appear on WhatsApp, YouTube, Snapchat
    3. the system overall has become slow to open apps
    4. Dark theme : the icon in the notification center has not appeared and all the screens are not on the dark theme
    Thank you
  8. Mithun_M_Shivaswamy Cupcake Jun 17, 2019
    please make sure that the files are in the direct internal storage (the file appear in the main folder list of your internal storage) then only the file appears in the local updated
  9. ApoorvVarma Cupcake Jun 17, 2019
    thanks for reply the jar is file is parallel to document, download, dcim and other folder is this is right path?
  10. chazey2 Ice Cream Sandwich Jun 17, 2019
    chazey2, Jun 17, 2019 :
    If it's .jar try changing the extension to .zip
    ironass likes this.
  11. ApoorvVarma Cupcake Jun 17, 2019
    thanks now it's visible
    Mithun_M_Shivaswamy likes this.
  12. bhushanvohra Cupcake Jun 17, 2019
    yes me to thinking to visit one plus centre
  13. FreshPrinceOfH Donut Jun 17, 2019
    FreshPrinceOfH, Jun 17, 2019 :
    Just rename the file to something like update.zip and make sure it's in the root. Local update will detect it after that.
  14. ApoorvVarma Cupcake Jun 17, 2019
    no not need I am now able to get the local download file, only now exploring this new Android q once i am done with the feature exploring i m going to rollback,
  15. ApoorvVarma Cupcake Jun 17, 2019
    yes it's only happening because the file of android q is of .zip which is correct ext for installing OS. in other hand the roll back file server is sending the file in .zip.jar just remove the .jar from it and try to rollback to android pie
  16. Naing Ko Cupcake Jun 17, 2019
  17. ApoorvVarma Cupcake Jun 17, 2019
    These are some finding on the beta version of Android Q on OnePlus 6T:
    1. First off all OP launcher is not working it's crashing all time I unlock and start using.
    2. Fingerprint sensor is not working but it's shows the background theme some time when I use keyboard and press space.
    3. Whole processing speed is slow.
    4. Function like night mode and inverted color are not supported and reading mode was not here.
    5. Found screen recorder and Zen mode feature new and can come handy.
    6. Whole 3 buttons back, home and of running apps are not working, I used different launcher but still running apps button was not worked.
  18. Pepa1977 Cupcake Jun 17, 2019
  19. Trevor.Hawkes Ice Cream Sandwich Jun 17, 2019
    Trevor.Hawkes, Jun 17, 2019 :
    First you need to search these forums. There are detailed instructions in quite a few posts.
    Second think about it and decide not to try it.
    Kytharsis likes this.
  20. Z1560608568563 Cupcake Jun 17, 2019
    Z1560608568563, Jun 17, 2019 :
    I don't know if it's just on my device, but I'm not able to cast anything to my Chromecast anymore. I'm rolling back today because this is a serious issue for me.
