73
Android Q Developer Preview 2 for OnePlus 6/6T
  1. Yeshutrozens Gingerbread Jun 18, 2019
    Yeshutrozens, Jun 18, 2019 :
    Issues with N
    Dark mode!! and some other applications!! Rather than this it's much better than Previous DP!!
  2. Yeshutrozens Gingerbread Jun 18, 2019
    TWRP !! Maybe that!!
  3. CYB3R0ID694 Gingerbread Jun 18, 2019
    CYB3R0ID694, Jun 18, 2019 :
    well Few Bugs I have noticed
    1. OP launcher crash
    fix :- Allow all permissions
    2. Frequent Google Play Service Crash
    no fix
    3.Apps Crashes while Switching
    no fix
    so far everything working fine include VoLTE.. Yes.. Both call and SMS working fine.. Atleast for me..
    GhostTeam and Barmenchik like this.
  4. U1513813701216 Gingerbread Jun 18, 2019
  5. CYB3R0ID694 Gingerbread Jun 18, 2019
    U1513813701216 likes this.
  6. U1513813701216 Gingerbread Jun 18, 2019
  7. CYB3R0ID694 Gingerbread Jun 18, 2019
    1st you need to Downgrade from OB to Stable then DP2
  8. U1513813701216 Gingerbread Jun 18, 2019
  9. CYB3R0ID694 Gingerbread Jun 18, 2019
    copy DP zip in pendrive
    now in local upgrade, Select stable Zip & click install(It will wipe your Device data)
    Reboot
    now skip all steps & Attach pendrive to Mobile & Copy DP zip in internal storage & again flash it using Local update(data wiped again)..
    done..
  10. U1513813701216 Gingerbread Jun 18, 2019
    U1513813701216, Jun 18, 2019 :
    CYB3R0ID694
    Reboot
    done..​
    it's not working
  11. CYB3R0ID694 Gingerbread Jun 18, 2019
  12. U1513813701216 Gingerbread Jun 18, 2019
    while flashing downgrade I got message
  13. jaygatsby9909 Honeycomb Jun 18, 2019
  14. U1513813701216 Gingerbread Jun 18, 2019
    there is no option in recovery to flash. really stuck.
  15. CYB3R0ID694 Gingerbread Jun 18, 2019
  16. U1513813701216 Gingerbread Jun 18, 2019
  17. CYB3R0ID694 Gingerbread Jun 18, 2019
    ok.. Let's make new start..
    Remove all Zip somewhere..
    now copy Rollback Zip in Internal Storage
    now use Local Upgrade & flash that zip(Data will get wiped at reboot)
    reboot & Skip all Steps then Copy DP2 zip in internal storage
    use Local Upgrade to flash it then reboot again
  18. Staufengalen Gingerbread Jun 18, 2019
    Staufengalen, Jun 18, 2019 :
    [QUOTE = "Yeshutrozens, post: 20443939, membro: 1672096"] TWRP !! Forse !! [/ CITAZIONE]
    [QUOTE = "Yeshutrozens, post: 20443939, membro: 1672096"] TWRP !! Forse !! [/ QUOTE]
    Verrai aggiornato in ota automaticamente
  19. Pepa1977 Cupcake Jun 18, 2019
    Pepa1977, Jun 18, 2019 :
    [QUOTE = "CYB3R0ID694, příspěvek: 20445293, člen: 1511667"]
    U1513813701216
    USB OTG funguje na DP2 nebo ne? prosím​
    vypadá mi dobře .. Na zdraví
    [ATTACH = full] 1044723 [/ ATTACH] [ATTACH = full] 1044726 [/ ATTACH] [/ QUOTE]
    Hey how can you do that? I'm not doing it on OPO6
  20. CYB3R0ID694 Gingerbread Jun 18, 2019
    just go in setting & enable OTG Storage..
    attach pendrive & Done..
    Check File manager
