79
Android Q Developer Preview 2 for OnePlus 6/6T
  1. Pepa1977 Cupcake Jun 18, 2019
    Pepa1977, Jun 18, 2019 :
    [QUOTE = "CYB3R0ID694, příspěvek: 20446547, člen: 1511667"] stačí jít do nastavení a povolit OTG Storage ..
    [ATTACH = plná] 1044980 [/ ATTACH]
    připojit pendrive & Hotovo ..
    Zkontrolujte Správce souborů [/ QUOTE]i
    didn't help, I tried a few times thanks.
  2. Jacksummers Froyo Jun 18, 2019
    Jacksummers, Jun 18, 2019 :
    ok so TMobile specific fajita users..if u want to use this new Q preview, u can, u just gotta be a bit tech savvy to do so. I offer no support as I have no time in life anymore so listen carefully..
    must have unlocked bootloader
    flash Q preview #1
    let it boot skip setup, reboot bootloader, leave here for now
    take Q preview 2 and unpack payload.bin using superr kitchen or do as I did and use payload.bin extractor.after this you have all images of the firmware.
    from terminal on PC, using fastboot flash pie boot image that's patched with twrp, from the phone tell it to reboot recovery.
    in twrp, from PC copy boot, system, and vendor to phone storage. Before doing so if it's encrypted, format(type yes)..then copy files.
    individually erase boot, system, and vendor. then using twrp flash each image, boot, system, and vendor. then format, and do a factory reset for good measure. then reboot to bootloader and using fastboot flash vbmeta from the Q 2 dump u extracted earlier. after this:
    reboot
    if all went well u should see Android logo and when it boots u have a less bug version of previous Q.
    only issues:
    no calls, just gorilla gargle sound
    dark mode derpy
    dev options funky, can't access it but can access the dev option specific settings by a reg settings search
    You CANNOT ROOT.
    if u do u lose audio. apparently Q audio crap is in the kernel. I verified this over and over today. the dpi should be 420.. it's 411 like the pixel 3 and the quick settings are too big. to fix this, root with a prepatched twrp kernel and then use adb sideload. install dpi changer app, change to 420. then reboot bootloader flash stock Q boot.img, reboot. while u are rooted audio doesn't work AT ALL. after u flash the unrooted kernel u are good and have audio.
    if setup is slow or u experience limited freezing, force reboot. anything seems as if the screen is flashing,reboot.
    otherwords,any issues reboot and wait a min after reboot to use the phone. it's buggy but I been using it for about 12 hrs. not bad at all.
    smarter minds need to figure out a way for magisk to allow patching the device's prop file to match any changes that take place in the kernel once it's rooted. that seems to interact with avb and or the audio hals. whew that was fun..now, anyone hiring.i need a job in the field..
  3. Jacksummers Froyo Jun 18, 2019
    and don't update op launcher. keep it as is.turn off play auto updates.if u do by mistake, go to apps, and uninstall updates..top.right corner u will have 3 dots
  4. U1513813701216 Gingerbread Jun 19, 2019
    U1513813701216, Jun 19, 2019 :
    back to stable, tried Q, I really surprised I found solution for flashing. I was tried several times but unable to flash rollback package and stable version of oos. Solutions -: I was change name of the zip files like stable.zip, downgrade.zip, developer preview.zip, but when I changed the name as it was in original stage I able to flash every above mentioned build. so wondering no one had solution I asked several times. thanks for help friends.
  5. Jacksummers Froyo Jun 19, 2019
    Jacksummers, Jun 19, 2019 :
    I believe the payload.manifest or something similar is not correct in the zip and not allowing the payload to fully deliver. my manual flashing and mixing of partitions have allowed a near flawless install. and includes features no one has mentioned.
  6. CYB3R0ID694 Gingerbread Jun 19, 2019
    CYB3R0ID694, Jun 19, 2019 :
    So far I found solution for this Bug..
    just Allow all Permissions & You are good to go...
    thanks me later mate..
    Jacksummers likes this.
  7. 4sheesh Honeycomb Jun 19, 2019
  8. LegolasX Jelly Bean Jun 20, 2019
    LegolasX, Jun 20, 2019 :
    you on CDMA?
    that's how their signal is displayed and its single sim bar.
    if you have 2 sims then you will have another set of similar icons.
  9. pmoar3 Froyo Jun 20, 2019
  10. CYB3R0ID694 Gingerbread Jun 20, 2019
    CYB3R0ID694, Jun 20, 2019 :
    It's known bug...
    sometimes after we reboot, Network data automatically set to the 2nd Sim..
    you should try another reboot..
  11. CYB3R0ID694 Gingerbread Jun 20, 2019
    Afaik, Yes as VoLTE Call & SMS working fine(Atleast for me)
  12. G_Karothikeyan Honeycomb Jun 20, 2019
    G_Karothikeyan, Jun 20, 2019 :
    How smooth this build...???
  13. G_Karothikeyan Honeycomb Jun 20, 2019
    Thanks @Manu J.
  14. Ching_Nam_Ip Froyo Jun 20, 2019
    Ching_Nam_Ip, Jun 20, 2019 :
    I already installed Android Q for nearly a week
    I have some opinions of it
    If you really want to install Q you have to take risk
    Also there have some bugs
    1. OnePlus launcher stop working
    Solution Uninstall launcher update
    2. Night mode not working
    3. invert colour not working
    4. Some bugs on UI , something stop working
    5. Camera recorder lag cannot hold 60 FPS
    6. Gesture bugs
    7. Turn on your phone need more time
    8. Phone is easily heat up eventually battery used up quickly
    What have been improved from DP1 to DP2
    1. Fast charge provided
    2. Fingerprint working
    3. New gesture
    4. More Stable
    Overall is not bad
    thanks for reading
  15. Vikas Patidar Cupcake Jun 20, 2019
    Vikas Patidar, Jun 20, 2019 :
    I have found many issues.
    1) Persistent notification about "Add another email account" in Settings.
    2) Sometimes devices freezes on home screen in other launchers. Just reboot the device and swipe on phone icon on lock screen and press the back or home key to load home screen correctly.
    3) Changing gesture navigation mode to Home and Back key will continuously flicker your screen. So Just reboot the device.
    4) Swipe Code on lockscreen is not available.
    5) One Plus removed Theme feature from display and Developer Settings.
    6) Accent color in Developer Settings is also not working, enabling it continuously flicker your screen.
    GhostTeam likes this.
  16. jaygatsby9909 Honeycomb Jun 20, 2019
    jaygatsby9909, Jun 20, 2019 :
    l think by this point most agree that OnePlus dropped a turd of an update. I understand it's a Developer Preview and all that and people can say what they want. But no matter how much you polish a turd (i.e. talk it up, say it's just a DP) it's still a turd.
  17. JuAnCaStRoP Gingerbread Jun 20, 2019
    JuAnCaStRoP, Jun 20, 2019 :
    So what I get from people is that only install it at your own risk. I just wish it was a full beta and not a DP. I don't get why they would release this to the public if is just for development.
    jaygatsby9909 likes this.
  18. Trevor.Hawkes Ice Cream Sandwich Jun 20, 2019
    Trevor.Hawkes, Jun 20, 2019 :
    It's stated quite clearly in the first post that you shouldn't install it unless you are a developer etc etc etc because
    " ITS IN THE EARLY STAGES OF DEVELOPMENT"
    You were warned not to install it but OnePlus obviously made the mistake of thinking they were talking to grown ups.
  19. JuAnCaStRoP Gingerbread Jun 20, 2019
    I know that. I just which they would release the beta version instead of the developer version.
  20. Trevor.Hawkes Ice Cream Sandwich Jun 20, 2019
    I would guess Beta is a way off yet and that they wanted to get the early adopters, especially the app developers, aware of the general framework of Q as early as possible.
    With the warnings they gave they probably never imagined, or didn't care, that ordinary noobs like us would try to use it.
    They will also be aware of the benefit of getting some form of Q out as early as they could.
