76
Android Q Developer Preview 2 for OnePlus 6/6T
  1. drl431 KitKat Jul 4, 2019
    drl431, Jul 4, 2019 :
    Also, there might be another (new) developer preview (DP3) within the next couple of weeks.
  2. Mashk Donut Jul 4, 2019
    Mashk, Jul 4, 2019 :
    [e]1f44d[/e] I'll wait for that instead of flashing backwards.
    Thanks alot.
    drl431 likes this.
  3. JuAnCaStRoP Gingerbread Jul 4, 2019
  4. drl431 KitKat Jul 4, 2019
    I think it would be better to wait for an Open Beta Q, than trying any developer preview.
    Maverick2.0 and ironass like this.
  5. Mashk Donut Jul 4, 2019
    Especially if it's your only or main phone.
  6. drl431 KitKat Jul 4, 2019
    Exactly!
  7. Staufengalen Gingerbread Jul 5, 2019
    Staufengalen, Jul 5, 2019 :
    Oneplus. 6 Openbeta 21. Ho scaricato lo zip android q dp 2 dal link ma non mi fa fare l'aggiornamento. come è stato aggirato il problema?
    grazie
  8. noor710 Cupcake Jul 6, 2019
    noor710, Jul 6, 2019 :
    m not able to install android q developer preview 1...its showing system installation failed
  9. drl431 KitKat Jul 6, 2019
    drl431, Jul 6, 2019 :
    The system will not allow you to install a package with a build date older than the current OOS build date.
    Also, you referred to DP1, but DP2 is out, and DP3 will follow in a couple of weeks.
  10. noor710 Cupcake Jul 6, 2019
    dp2 also not installing
  11. drl431 KitKat Jul 6, 2019
    What is your current OOS?
  12. noor710 Cupcake Jul 6, 2019
  13. drl431 KitKat Jul 6, 2019
    That's new and has a build date of june 25. DP2 is older with a build date of may 30.
    K1546869398185 and noor710 like this.
  14. noor710 Cupcake Jul 6, 2019
    ok got it
    thanks
    really appreciate it
    drl431 likes this.
  15. jaygatsby9909 Honeycomb Jul 7, 2019
    jaygatsby9909, Jul 7, 2019 :
    So ready to see what OnePlus releases next (July 12 maybe?). I just hope it's usable unlike this.
    iDrewn and Jacksummers like this.
  16. umair lakdawala Donut Jul 8, 2019
    umair lakdawala, Jul 8, 2019 :
    I am trying to install local zip but getting below error.
    ''THIS VERSION HAS NO CHANGELOG''
    Please guide me...
  17. siddhesh2k Froyo Jul 8, 2019
    siddhesh2k, Jul 8, 2019 :
    its not error it shows like that only but has no problem. mine also shown same and also successfully completed . did you faced any problem like it didn't flashed/installed like that ?
  18. umair lakdawala Donut Jul 8, 2019
    Yeah i got installation failed message.
    siddhesh2k likes this.
  19. Srikanthsharma Cupcake Jul 9, 2019
  20. Srikanthsharma Cupcake Jul 9, 2019
