81
Android Q Developer Preview 2 for OnePlus 6/6T
  1. itssandeepd
    Honeycomb Jul 13, 2019
    itssandeepd , Jul 13, 2019 :
    *I actually don't need when dp3 gonna come but I'll ask anyway so that It'll be the 500th comment on this post*
    DP3 when?
  2. Saidinho84
    Froyo Jul 13, 2019
  3. withbsal
    Donut Jul 13, 2019
    withbsal , Jul 13, 2019 :
    yeah hope so
  4. drl431
    KitKat Jul 13, 2019
    drl431 , Jul 13, 2019 :
    If you need a daily driver, I would wait for the Q open beta, next fall.
  5. I1551670766113
    Cupcake Jul 14, 2019
    I1551670766113 , Jul 14, 2019 :
    Why I cannot using Android q beta 5 on my oneplus 6t . When I am going to install it by local upgrade it's showing that upgrade is failed please help me
  6. LegolasX
    Jelly Bean Jul 14, 2019
    ironass and Kytharsis like this.
  7. G_Evan_Copp_(Evanawesome
    Froyo Jul 14, 2019
    G_Evan_Copp_(Evanawesome , Jul 14, 2019 :
    He's probably installing the build for pixels *rolling eyes*
    Kytharsis likes this.
  8. Cervantes
    Lollipop Moderator Jul 14, 2019
    Cervantes , Jul 14, 2019 :
    Hi
    according to this announcement it is for developers and it is the preview 2
    The preview thread is a thread of questions and/or commentary
    Thread merged
  9. kalsirajan99@gma
    Donut Jul 14, 2019
    Pratik Magadwar likes this.
  10. Pepa1977
    Donut Jul 14, 2019
    Pepa1977 , Jul 14, 2019 :
    [QUOTE = "kalsirajan99 @ gma, příspěvek: 20544982, člen: 2074545"] pokud používám Android q dp2
    pak další aktualizace dp3, kterou vývojáři posouvají ota ?? [/ QUOTE]
    Not
  11. Pratik Magadwar
    Eclair Jul 14, 2019
    Pratik Magadwar , Jul 14, 2019 :
    kalsirajan99@gma
    if am running Android q dp2
    then the next dp3 update pushing by developers through ota ??
    you will not receive ota ..dp3 will be independent build and shifting from dp2 to dp3 will wipe all user and system data
  12. kalsirajan99@gma
    Donut Jul 14, 2019
    kalsirajan99@gma , Jul 14, 2019 :
    ok thanks bro
  13. syedrhashmi
    Eclair Jul 14, 2019
  14. drl431
    KitKat Jul 14, 2019
    drl431 , Jul 14, 2019 :
    OnePlus does not release ETA's, but maybe soon.
  15. Sapneshshah
    Eclair Jul 14, 2019
    Sapneshshah , Jul 14, 2019 :
    Under latest beta version camera does not work properly. Auto focus has an issue, portrait in selfie does not work.
  16. kalsirajan99@gma
    Donut Jul 14, 2019
    which version you used ??
  17. Sapneshshah
    Eclair Jul 14, 2019
  18. kalsirajan99@gma
    Donut Jul 14, 2019
  19. drl431
    KitKat Jul 14, 2019
    That is an OP7 camera apk that you side loaded. It wont work well in an OP6/6t.
    ironass likes this.
  20. Marek_Orovnicky
    Honeycomb Jul 14, 2019
