81
Android Q Developer Preview 2 for OnePlus 6/6T
  1. maanavgohil
    Cupcake Jul 17, 2019
  2. maanavgohil
    maanavgohil , Jul 17, 2019 :
    yes I'm facing same problem
    plz help me if you got suggestions
  3. Aasim K
    Froyo Jul 17, 2019
    Aasim K , Jul 17, 2019 :
    Cant you just search or read, literally some above posts it is clearly mentioned about this error.
    As Q Dev preview is based on Lower OOS verison so Higher level of OOS version does not let it install.You need to Downgrade to lower oos version to install.
    Also its not beta,its Developer preview.Stay away if you dont know what you are getting into.Better wait for BETA.
  4. maanavgohil
    oh thanks a lot for your information.
    I appreciate your reply.
    Aasim K likes this.
  5. maanavgohil
    one more question I need to ask you if you can reply me please
  6. maanavgohil
    I am not able to go in recovery mode to install any of the ROM
    even I have oneplus 3T I can do with this phone but I am not able to do with 6t
  7. Mashk
    Donut Jul 17, 2019
    Mashk , Jul 17, 2019 :
    You must have OEM unlock 'ON' then find a guide to install a custom recovery.
    Flashing the dev or beta doesn't require a custom recovery.
    You update from Local Upgrade under System Update.
  8. maanavgohil
    I am trying to update with Android q but I am not able to do with local update
    I think if I will try with the recovery mode it will done but I am not able to go in recovery mode
  9. Mashk
    Donut Jul 17, 2019
    Come on dude! This has already been explained to you #542
  10. maanavgohil
    [e]1f64f[/e]
    laikexpert likes this.
  11. jaygatsby9909
    Honeycomb Jul 17, 2019
    jaygatsby9909 , Jul 17, 2019 :
    The real question is why install this anyway? The new release is probably 2 days away. Just wait. This version has TONS of bugs. Just wait.
    Xcutioner and kalsirajan99@gma like this.
  12. Xcutioner
    Gingerbread Jul 17, 2019
  13. Staufengalen
    Staufengalen , Jul 17, 2019 :
    Quindi sembra non ci sia una spiegazione concreta del perché molti non riescono ad installare dp2 su oneplus 6?
    ho disinstallato openbeta 22 passando alle versione ufficiale 9.07 e non ha funzionato...
    domanda forse si deve installare la dp1 e aggiornare alla dp2 ?
  14. Staufengalen
    non serve non funziona comunque. l'ho fatto io
  15. amirhussaini93
    Ice Cream Sandwich Jul 18, 2019
    amirhussaini93 , Jul 18, 2019 :
    Get ready, Android Q Developer Preview 3 will coming to 6/6T maybe this week or next week.
    Because HydrogenOS Q DP3 already released for 7 Series.
    Probably need clean flash (need to format data after update) :D
    Seem like lot of new things, but on 7 Series. Idk 6/6T will get same or not. (like new lockscreen clock, Horizon light and many more)
  16. sohailss11
    Donut Jul 18, 2019
  17. Marwadi_Rahul
    Eclair Jul 18, 2019
  18. Ching_Nam_Ip
    Gingerbread Jul 18, 2019
  19. itssandeepd
    Honeycomb Jul 18, 2019
    Pratik Magadwar likes this.
  20. Ching_Nam_Ip
