106
Android Q Developer Preview 2 for OnePlus 7 Pro & 7
  1. Manu J.
    OxygenOS Product Staff Member Jun 20, 2019
    Manu J. , Jun 20, 2019 :
    OnePlus 7 Series gets Android Q Developer Preview 2!
    As the name suggests, this build of Android Q is best suited for developers and early adopters. As it is still in an early stage of development, we do not recommend flashing this ROM if you have little or no experience in software development or flashing custom ROMs. Proceed at your own risk!
    Caution: You should understand the risk of BRICKING your phone, read the instructions carefully and be 100% sure of what you are doing, and please always backup your important data before flashing.
    Known Issues
    1. Reading mode doesn't work
    2. Display mode doesn't work
    3. The verification window can't pop up in WIFI anonymous connection
    4. Low probability of having stability issues
    Please note: This instruction is only for OnePlus 7/7 Pro, and please make sure the battery level is above 30% and minimum 3GB of available storage space.
    MP version = Stable official version
    DP version = Developer Preview version
    MP to DP upgrade guide—via Local OTA Update
    Note: This upgrade method will erase all the contents of the phone, please be sure to backup first.
    1. Download the latest ROM upgrade zip package from the specified server.
    2. Copy the ROM upgrade package to the phone storage.
    3. Go to Settings -> System -> System Updates -> Click top right icon -> Local upgrade -> Click on the corresponding installation package -> upgrade -> System upgrade completed to 100%.
    4. After the upgrade is complete, click Restart.
    5. The phone will boot into recovery mode to format user data, it will reboot again after formatting.
    6. Update successful.
    DP to MP rollback guide - via Local OTA update
    2. Copy the Rollback package to the phone storage.
    Ready to get started on the Android Q Beta?
    Upgrade from DP1 to DP2 (No data loss/local upgrade)
    Want to go back to Android Pie? Download the Rollback package from the links below:
    As always, please share your feedback through https://forums.oneplus.com/feedback/.
    Never Settle.
  2. YRJ
    The Lab - OnePlus 7T Reviewer; Community Hero 2020 Jun 20, 2019
    YRJ , Jun 20, 2019 :
    wow! that was fast. hope that people consider the risk before updating.
    thanks and keep up the good work :)
  3. akks
    KitKat Jun 20, 2019
    akks , Jun 20, 2019 :
    Wow! That's fast.
    Thank you, OnePlus for your awesome work.
  4. K1560532568494
    Froyo Jun 20, 2019
  5. aadi_vasi
    Honeycomb Jun 20, 2019
  6. DenisST
    Eclair Jun 20, 2019
  7. PocketnowJules
    Cupcake Jun 20, 2019
    PocketnowJules , Jun 20, 2019 :
    Just a quick Q: is DP2 based on DP1 with updates and fixes or a later mainline Android Q Beta, perhaps with final APIs?
    H1559976493122 likes this.
  8. Chrispost1
    Donut Jun 20, 2019
    Chrispost1 , Jun 20, 2019 :
    Thank you Oneplus!!! I can't turn my phone on or off after the second reboot. DON'T INSTALL THIS!!! I can't do anything with my phone right now........
  9. kannaa_kr
    Froyo Jun 20, 2019
    Shajahankm likes this.
  10. F1536011049830
    Eclair Jun 20, 2019
  11. Moin2200
    KitKat Jun 20, 2019
  12. derLenno
    The Lab - OnePlus 6 Reviewer Jun 20, 2019
    derLenno , Jun 20, 2019 :
    Oh no, did someone say DEVELOPER PREVIEW?
    If you don't know how to fix your stuff, don't flash DEVELOPER PREVIEWS
  13. Lunatico
    Jelly Bean Jun 20, 2019
    Lunatico , Jun 20, 2019 :
    How about reading the whole post before flashing DP?! !
    Texasaggie1, stemgal, nateavi and 8 others like this.
  14. G_Karothikeyan
    Ice Cream Sandwich Jun 20, 2019
    G_Karothikeyan , Jun 20, 2019 :
    OMG...... Thanks @one plus team and @Manu J.
    Texasaggie1 and nateavi like this.
  15. G_Karothikeyan
    OMG:flushed::flushed::flushed::flushed:
  16. GameAholicFTW
    Eclair Jun 20, 2019
    GameAholicFTW , Jun 20, 2019 :
    Sigh... Not their fault when you don't read the description...
  17. stefan_ddorf
    stefan_ddorf , Jun 20, 2019 :
    Press Power and Vol Up simultaneously, your phone should power up again.
    There's a reason why this build is called developer Preview, you can't expect a stable build to use as daily driver!
  18. WillM_TX
    Donut Jun 20, 2019
    R1562904996066 likes this.
  19. Chrispost1
    Donut Jun 20, 2019
    Of course I know how to flash it properly and it worked, well the launcher crashed every second, but after I turned the phone off it didn't boot again... Seems like the same issue Pixel phones have with the Q beta.
  20. keeratsawhney
    Gingerbread Jun 20, 2019
