104
Android Q Developer Preview 2 for OnePlus 7 Pro & 7
  1. taifuller
    Donut Jun 29, 2019
  2. TheMysticalShaman
    Honeycomb Jun 30, 2019
    knrd and G_Сергей_Мика like this.
  3. Oneyedmonkey
    Honeycomb Jul 1, 2019
    Oneyedmonkey , Jul 1, 2019 :
    Wow really? Is that why they call it unstable and a developer preview?
    winter128 likes this.
  4. H1561960043803
    Ice Cream Sandwich Jul 1, 2019
  5. G_Julian_Schneidermann_u
    Cupcake Jul 1, 2019
  6. azu1414
    Eclair Jul 1, 2019
    azu1414 , Jul 1, 2019 :
    I flashed the international software and then tried the Android Q betas. I was successful in flashing them but wouldn't recommend if you're wanting to use it as a daily driver.
    I think it's fun to see what's coming up, even if I have to unbrick and restore my device. Unless you're a Dev, I wouldn't recommend flashing this, but the next betas should be exciting! ʘ‿ʘ
    H1561960043803 and AdikartaDasa like this.
  7. PGopalakrishnan
    Eclair Jul 2, 2019
    knrd likes this.
  8. H1561960043803
    Ice Cream Sandwich Jul 2, 2019
    H1561960043803 , Jul 2, 2019 :
    thank you, I will wait. I've been on iOS for past 2 years ( not proud) but happy to be back on Android, just rusty at flashing and root etc...
    azu1414 likes this.
  9. Atiq1989
    Froyo Jul 3, 2019
    Atiq1989 , Jul 3, 2019 :
    When i use charger then mobile to much heating and accidentally touch issue after rollback Android P.
    i update DP2 but mobile lots of bugs are there, then i rollback ANDROID P. kindly check and Resolve my issue ASAP. @Manu J. @Celia C
  10. Sopheak_Noun
    Froyo Jul 3, 2019
    knrd likes this.
  11. Huigiebaby
    Honeycomb Jul 3, 2019
  12. R1528752001541
    Froyo Jul 3, 2019
  13. R1528752001541
    Froyo Jul 3, 2019
  14. G_RAJASEKAR_T_lHVx
    Eclair Jul 3, 2019
    G_RAJASEKAR_T_lHVx , Jul 3, 2019 :
    The camera interface needs a revamp. Plus include a feature to tap anywhere to take a photo and not the shutter button alone.
  15. C1561879185775
    Donut Jul 3, 2019
    C1561879185775 , Jul 3, 2019 :
    I went through same issue.. and after a bit of research I was successful to bring my phone on normal state.. try going at recovery by pressing volume down and power key...if u struck at no command option... keep pressing power volume keys randomly... u will eventually be directed to recovery. then do factory reset. reboot... the system will work. then download Stable full rom and update through local upgrade option.
    Huigiebaby likes this.
  16. C1561879185775
    Donut Jul 3, 2019
    I went through same issue.. I can feel your pain.. and after a bit of research I was successful to bring my phone on normal state.. try going at recovery by pressing volume down and power key...if u struck at no command option... keep pressing power volume keys randomly... u will eventually be directed to recovery. then do factory reset. reboot... the system will work. then download Stable full rom and update through local upgrade option.
    Sopheak_Noun likes this.
  17. C1561879185775
    Donut Jul 3, 2019
    I think bootloop after restarting a phone on DP2 should be mentioned as known issue so that non dev user wouldn't brick their phone.
  18. PGopalakrishnan
    Eclair Jul 3, 2019
  19. atLeeroyJenkins
    Froyo Jul 3, 2019
    atLeeroyJenkins , Jul 3, 2019 :
    Does this Beta already include the new Google Gesture Navigation? I prefer it over OnePlus for Gestures
  20. PGopalakrishnan
    Eclair Jul 3, 2019
