101
Android Q Developer Preview 2 for OnePlus 7 Pro & 7
  1. H1561960043803 Donut Jul 4, 2019
    H1561960043803, Jul 4, 2019 :
    for some. not all. and has it's issues. you should probably read the thread
  2. TheMysticalShaman Gingerbread Jul 4, 2019
    TheMysticalShaman, Jul 4, 2019 :
    Fact is that there are those very eager for the latest OS aka Android version. In the past, it was difficult to get the latest with waiting, usually having to root the device. Easy access to the latest can be good but it can also be a curse. Grabbing unstable because you can, you want it now instead of waiting for stable. That can bite you very hard as some found out with the garbage developer preview.
  3. Vikasg1977 Cupcake Jul 5, 2019
    Vikasg1977, Jul 5, 2019 :
    folks, I bricked my phone after an hour of installation, phone gets stuck on Android logo... recovery does not work gets stuck at Android logo with "no command".. has somebody seen this issue? I am a newbie here.. please help!
    I know I should have read more before installing, but I am stuck, I have tried probably every step mentioned in support pages.. but nogo . help!! TIA
    thanks a ton folks, was able to revive my phone... :)
  4. azu1414 Eclair Jul 5, 2019
    azu1414, Jul 5, 2019 :
    Hey, Vikasg! I'd recommend checking out the unbrick mega thread. That and threads on that topic will be your best bets. There are also some great comments within this thread that have abridged instructions on how to unbrick your OP. Best of luck!
    Vikasg1977, RaMi83 and H1561960043803 like this.
  5. RaMi83 Eclair Jul 5, 2019
    RaMi83, Jul 5, 2019 :
    no
    falfaro likes this.
  6. F_Jen_Bajracharya_xNEV Cupcake Jul 5, 2019
  7. bisserv Cupcake Jul 5, 2019
    bisserv, Jul 5, 2019 :
    Hi mate,
    Read my post from Wednesday.
    Vikasg1977 and azu1414 like this.
  8. G_Srimanth_Yarlagadda_Oj Eclair Jul 5, 2019
    G_Srimanth_Yarlagadda_Oj, Jul 5, 2019 :
    Feature to customize status bar icons on 7. Notch really limits the icons.
    Disable notch completely option. Including status bar icons and not just notch.
  9. G_Srimanth_Yarlagadda_Oj Eclair Jul 5, 2019
  10. Pirnie Cupcake Jul 5, 2019
    Pirnie, Jul 5, 2019 :
    I unbricked by following the steps I originally took to make my T-Mobile an international version. It worked for me.
    https://www.xda-developers.com/t-mobile-oneplus-7-pro-international-firmware-install/
  11. falfaro Cupcake Jul 5, 2019
  12. anasmhds Eclair Jul 8, 2019
    anasmhds, Jul 8, 2019 :
    Any news about the new version, version 3,,, we expect it to be more stable for developers preview
  13. Marek_Orovnicky Gingerbread Jul 8, 2019
    Marek_Orovnicky, Jul 8, 2019 :
    in about 2 weeks or so
  14. J1562692611687 Cupcake Jul 9, 2019
    J1562692611687, Jul 9, 2019 :
    While it works fine, I find my touch screen responsiveness to be a bit hit and miss, especially around the edges (for example when I had a tip on using touch bar for gestures control I wasn't able to close it).Is it just my phone?
    RaMi83 likes this.
  15. RaMi83 Eclair Jul 9, 2019
    RaMi83, Jul 9, 2019 :
    same here, and also during calls with the notification panel
  16. Pirnie Cupcake Jul 10, 2019
    Pirnie, Jul 10, 2019 :
    I've done that. After a couple reboots, I was stuck in a loop at start-up. I added the weather widget to my home screen and that's where everything went bad for me. Fell back to Pie.
  17. isorce Froyo Jul 10, 2019
    AdikartaDasa likes this.
  18. toastytoast1234 Marshmallow Jul 10, 2019
  19. G_GOPALAKRISHNAN Donut Jul 11, 2019
    apat26 likes this.
  20. alvarorod_ Donut Jul 11, 2019
