101
Android Q Developer Preview 2 for OnePlus 7 Pro & 7
  1. apat26 Eclair Jul 11, 2019
    apat26, Jul 11, 2019 :
    Just power off and then keep pressing volume up and power button until reboot.
    flash full downgrade file through local system update
  2. alvarorod_ Donut Jul 11, 2019
  3. apat26 Eclair Jul 11, 2019
    I am on Q and looks like small small issues here and there but working ok. Did a factory reset after flagging dp1 first, then dp2 on top, then factory reset.
    just don't update oneplus launcher. If you do by mistake, uninstall the update.
    I am on Nova launcher now but one plus launcher old version works ok.
  4. alvarorod_ Donut Jul 11, 2019
    alvarorod_, Jul 11, 2019 :
    i have to use the .zip.jar no
  5. apat26 Eclair Jul 11, 2019
    alvarorod_
    i have to use the .zip.jar no​
    .zip yes
    honestly,I haven't gone back yet but soon will go back.
    just wanted to check this developer preview.
  6. alvarorod_ Donut Jul 11, 2019
    if I press volum - and power --> no command
  7. alvarorod_ Donut Jul 11, 2019
    and volume up + power, nothing
  8. apat26 Eclair Jul 11, 2019
    alvarorod_
    and volume up + power, nothing​
    Sorry...if your phone is working ok, directly go to local system update and do it
    is it not working that way?
  9. pritam242 Cupcake Jul 11, 2019
    pritam242, Jul 11, 2019 :
    Can any body suggest, while I am connecting earphone via audio adapter (type c) no body abale to listen my voice in incoming & outgoing calls as well..
  10. Huigiebaby Honeycomb Jul 11, 2019
    Loper_fan likes this.
  11. alvarorod_ Donut Jul 11, 2019
    no...
  12. garyharris1986 Eclair Jul 11, 2019
    garyharris1986, Jul 11, 2019 :
    You'd also think they would pull this ROM.
  13. apat26 Eclair Jul 11, 2019
    just saying no won't let anyone here help you out.
    explain in detail where you are stuck.
    All the pages here are filled with strict warning not to flash by regular users.
    That's why it is named developer preview.
  14. G_GOPALAKRISHNAN Donut Jul 11, 2019
  15. anasmhds Eclair Jul 11, 2019
    anasmhds, Jul 11, 2019 :
    Tried the Chinese version for 3 days wasn't good enough, sound was low, touch screen bug, gestures bug, no play store...etc.
    tried this version, the Google updated launcher automatically and the phone is brick...
    back to stable version immediately...
  16. Huigiebaby Honeycomb Jul 11, 2019
    Huigiebaby, Jul 11, 2019 :
    They don't care.
  17. Colinm428 Gingerbread Jul 11, 2019
    Colinm428, Jul 11, 2019 :
    Everyone saying it's stuck at the boot screen and bricked it really isn't! If you get the "no command" message trying to get into recovery all you have to do is hold the power button and tap volume up. When the menu comes up wipe the phone and set it up. Without doing anything else when it boots up put the rollback file on your device and manually install it.
  18. src52 Cupcake Jul 12, 2019
    src52, Jul 12, 2019 :
    It's literally a ******* DEVELOPER PREVIEW. They have no reason to pull it because they never once claimed it was "bug free, daily driver ready". In fact, they literally said the opposite. It's purely for developers to test their apps and programs on it beforehand. Instead you get people who install it thinking it's public release ready, whining and complaining when things go wrong after they were very concisely warned about the risks before downloading. I swear, it's like you people don't have the ability to read.
  19. Huigiebaby Honeycomb Jul 12, 2019
    Huigiebaby, Jul 12, 2019 :
    How are they going to collect useful data when every install gets borked in no time? How are you going to develop anything when it won't boot after a few restarts? There is a difference between buggy aka not stable and borked. If you do not get that, bye.
    anasmhds likes this.
  20. TheMysticalShaman Gingerbread Jul 12, 2019
    TheMysticalShaman, Jul 12, 2019 :
    People are too eager to get the latest OS. The Developer Preview shouldn't be that easy to get. Should be only available to those who have rooted their phones. Basically, having the tech savvy to do so. Instead, too easy. Basically, it is a form of malpractice to offer the Developer Preview to everyone, not everyone is a tech whiz. Not everyone is a developer. Making the developer preview available to all is completely irresponsible of oneplus. Resulting in many bricked oneplus devices. I wouldn't blame anyone who got their device bricked with the Developer Preview to switch to Samsung or Apple
    the_reckoner likes this.
