101
Android Q Developer Preview 2 for OnePlus 7 Pro & 7
  1. keeratsawhney Froyo Jun 20, 2019
  2. keeratsawhney Froyo Jun 20, 2019
    keeratsawhney, Jun 20, 2019 :
    Also if you happen to struck with bootloop after restart hold volume down and Power untill you see a little Android Icon you will then enter the recovery. Factory Reset the device you will be back into the os. If you want to stay or want to roll back upto you then. Fastboot ( Bootloader ) will not work.
    nateavi likes this.
  3. F_Freddy_Xu_GxgJ Froyo Jun 20, 2019
    Tostasa and Z1560664890178 like this.
  4. Moin2200 KitKat Jun 20, 2019
    Moin2200, Jun 20, 2019 :
    It's not an upgrade it's a developer preview.
  5. M1549732850251 Cupcake Jun 20, 2019
  6. G_ayush_madan_YhBr Honeycomb Jun 20, 2019
    Achman and RBeck like this.
  7. anasmhds Eclair Jun 20, 2019
    anasmhds, Jun 20, 2019 :
    Did reboot and stuck with android logo :(, i got the little Android Icon but never entered the recovery, what to do??
    H1559976493122 and Drewgaren like this.
  8. keeratsawhney Froyo Jun 20, 2019
    Press power key or volume keys .
  9. Deagle311 Donut Jun 20, 2019
  10. JigneshJain Froyo Jun 20, 2019
    JigneshJain, Jun 20, 2019 :
    I am figuring out,
    what I did is used adb commands while on android logo
    "adb reboot fastboot"
    then I will flash fastboot rom from fastboot
    recovery isnt available for me too
  11. Eslavath_Roshan Honeycomb Jun 20, 2019
  12. anesh007 Honeycomb Jun 20, 2019
    anesh007, Jun 20, 2019 :
    i think u should give oxygen beta rom for op7p . Q developer rom has many bugs so very few user will install it
    waiting for oxygen beta rom
    H1559976493122 likes this.
  13. anasmhds Eclair Jun 20, 2019
    did the same not entering the recovery
  14. anasmhds Eclair Jun 20, 2019
    let me try...
    Z1560664890178 likes this.
  15. anasmhds Eclair Jun 20, 2019
  16. JigneshJain Froyo Jun 20, 2019
    still downloading files.
    I guess only unbrick tool is option then
  17. the_reckoner Ice Cream Sandwich Jun 20, 2019
    Drewgaren and HardstylerDK like this.
  18. vjgeorge87 Froyo Jun 20, 2019
    #38
  19. keeratsawhney Froyo Jun 20, 2019
    What are you doing ?? hold Volume up and power on Android logo then go to factory reset
    #39
  20. jerrymilton Jelly Bean Jun 20, 2019
    #40
