93
Android Q Developer Preview 2 for OnePlus 7 Pro & 7
  1. anasmhds Eclair Jun 20, 2019
    anasmhds, Jun 20, 2019 :
    did the same Volume up and power on Android logo then not able to make a factory reset because android logo is not moving
    recovery isnt available for me
    i know what iam doing, i did the same for Hos beta Q2, but recovery was available..
    #41
  2. Tostasa Eclair Jun 20, 2019
    #42
  3. konomasa Gingerbread Jun 20, 2019
    konomasa, Jun 20, 2019 :
    this is a dp not a place to complain about the camera which is really good in fact.
    #43
  4. HardstylerDK Eclair Jun 20, 2019
    HardstylerDK, Jun 20, 2019 :
    This is only for developers. Don't do this if you have little to none experince with flashing Roms!
    #44
    H1559976493122, Daasty and elanglois like this.
  5. Mingo_MGx Donut Jun 20, 2019
    #45
    H1559976493122 likes this.
  6. stefan_ddorf Jelly Bean Jun 20, 2019
    stefan_ddorf, Jun 20, 2019 :
    Once again, it isn't an upgrade! It's a developer built that isn't finished completely, it's meant to offer an possibly to developers to adapt their apps to Q. Or for experienced user who want to take a look at the upcoming version of Android.
    So you won't get it automatically. And if you use for phone as daily driver, it isn't recommended to install it manually at all!
    #46
  7. elanglois Lollipop Jun 20, 2019
    elanglois, Jun 20, 2019 :
    the instructions were very specific. If you don't know how to fix it from where you are, then you should not have installed it in the first place.
    obviously, other people have installed it and it's working just fine. So, it's not the update. You were instructed not to install it if you didn't know what you were doing
    #47
  8. elanglois Lollipop Jun 20, 2019
    @anasmhds
    i know what iam doing, i did the same for Hos beta Q2, but recovery was available..​
    obviously you do not know what you're doing. Otherwise, you wouldn't have any issues. What do you do when you can't access recovery?
    If you somehow toast recovery, you have to be prepared to use fastboot to get in and fix it
    #48
    slandsiedel likes this.
  9. ashrayvk Cupcake Jun 20, 2019
    ashrayvk, Jun 20, 2019 :
    looks like if you update the default launcher, it goes into a continuous crash loop. I've disabled the auto update on that app currently, and rolled back to the OnePlus launcher that came with this build.
    #49
  10. garyharris1986 Eclair Jun 20, 2019
    garyharris1986, Jun 20, 2019 :
    Can confirm, this ROM is unusable. I got it to run a while by changing launcher, but it still ended up in a bootloop on rebooting a few times. The gestures wont work...cant use recent apps after trying to switch to gestures and back. Had to use msm to get it back running as it hoses fastboot too.
    #50
    Polishow, Hitman424 and Huigiebaby like this.
  11. Tostasa Eclair Jun 20, 2019
    Tostasa, Jun 20, 2019 :
    Oh guy... I know it but i said 'update' because i hadn't batter word in english :p i'm such a extended user and i know what i do :)
    #51
    Daasty likes this.
  12. anasmhds Eclair Jun 20, 2019
    this is the reason exactly, but i dont know how toast my recovery
    #52
  13. ashrayvk Cupcake Jun 20, 2019
    you can install a different launcher from the play store, or otherwise, go to apps section and uninstall updates for the launcher app. post that, go ahead and disable auto updates on play store.
    #53
  14. Hitman424 Gingerbread Jun 20, 2019
    Hitman424, Jun 20, 2019 :
    exactly bro...but of course people dont read where it says you can BRICK your phone and will try it anyways.....lol.
    #54
  15. tomerlandsen Donut Jun 20, 2019
    #55
    FlixbusLennart likes this.
  16. JigneshJain Cupcake Jun 20, 2019
    JigneshJain, Jun 20, 2019 :
    Finally devices recovered with unbrick tool.
    those who havent yet reboot and not stuck in boot screen enable usb debugging and oem unlock button so in case you are stuck can flash recovery and other commands from fastboot.
    #56
    JeremyGriffiths likes this.
  17. 7 Delusions Froyo Jun 20, 2019
    7 Delusions, Jun 20, 2019 :
    Can confirm device gets into bootloop after a few restarts.Wanted to try it considering that 90hz problem was not listed anymore, but the fluidity of the device doesn't seem at all like using 90 hz.
    #57
  18. rahulpatil2009 Cupcake Jun 20, 2019
    rahulpatil2009, Jun 20, 2019 :
    Can you please let us know how to recover using unbrick tool? My device is stuck at boot screen.
    #58
  19. JigneshJain Cupcake Jun 20, 2019
    if it's showing android logo
    connect to pc and type command "adb reboot fastboot"
    in fastboot power off phone and start unbrick tool available (search for it if you don't know)
    if unable to use adb command press hold power on + volume up and down simultaneously when you feel vibration leave power button and connect USB to pc and start unbrick tool.
    #59
    Erik_Hermsen likes this.
  20. rahulpatil2009 Cupcake Jun 20, 2019
    Okay - I will try this. Thank you!
    #60
