101
Android Q Developer Preview 2 for OnePlus 7 Pro & 7
  1. rahulpatil2009 Cupcake Jun 20, 2019
    rahulpatil2009, Jun 20, 2019 :
    I was able to restore my device using Unbrick tool. Many many thanks to you for pointing me to the right direction!
    #61
  2. Mystenes Cupcake Jun 20, 2019
    Mystenes, Jun 20, 2019 :
    holding power on + both volume buttons helped me to see my phone in unbrick tool
    #62
  3. rollerk Eclair Jun 20, 2019
    rollerk, Jun 20, 2019 :
    can someone summarize the usability of this Dev Prev 2 build? is it worth to install as a daily driver? thanks.
    #63
  4. G_paul_Johnson_XiSw Cupcake Jun 21, 2019
    G_paul_Johnson_XiSw, Jun 21, 2019 :
    I'm pretty sure they read you the warnings before installing...so, who's fault is it?
    #64
  5. shineproductions Cupcake Jun 21, 2019
    shineproductions, Jun 21, 2019 :
    Right after the installation of Oneplus 7 Pro Android Q Developer Preview # 2, during the initial setup, the Gboard virtual keyboard was crashing when trying to setup WIFI. I had to retry multiple times to get past this. Then the same exact situation Chrispost1 experienced, with the Oneplus launcher crashing repeatedly, happened to me. So I rebooted the phone and now it gets stuck on the "android" animation, but will not go any further. If I try to boot into Recovery Mode It displays the Green android icon with a red X. I can get into Fastboot Mode though. Please, how can I unbrick my beautiful Oneplus 7 Pro? Thanks in advance for any assistance!
    #65
  6. shineproductions Cupcake Jun 21, 2019
    Why is there a need to blame anybody, or attach fault? He simply asked for assistance and reported a potential issue. When customers install the Developer previews they are actually helping Oneplus, and Google and this reporting back of issues is a necessary stage of the development of this new software.
    #66
    G_Rich_Cowan_EQlj and anasmhds like this.
  7. G_paul_Johnson_XiSw Cupcake Jun 21, 2019
    yeah..you obviously just skimmed what he said. So I'm not going to justify what I wrote, to you.
    #67
  8. S1559556411393 Cupcake Jun 21, 2019
    S1559556411393, Jun 21, 2019 :
    woooow never seen something like this, excellent work [e]1f44d[/e][e]1f44d[/e][e]1f44d[/e][e]1f44d[/e]
    #68
  9. Drewgaren Eclair Jun 21, 2019
    #69
    anasmhds likes this.
  10. gururoop Donut Jun 21, 2019
    gururoop, Jun 21, 2019 :
    Has anyone been able to install this and reboot multiple times without boot-looping? Please share how did you manage to prevent the boot-loops.
    #70
  11. Drewgaren Eclair Jun 21, 2019
    Drewgaren, Jun 21, 2019 :
    ha no
    #71
  12. G_GOPALAKRISHNAN Donut Jun 21, 2019
    #72
  13. JigneshJain Froyo Jun 21, 2019
    JigneshJain, Jun 21, 2019 :
    I will try again with update method from dp1 to dp2 reboot may be working from that I guess.
    since their devs must have used that way chances are high of it working
    #73
  14. Drewgaren Eclair Jun 21, 2019
    report back if anything is better.
    #74
  15. G_GOPALAKRISHNAN Donut Jun 21, 2019
    #75
  16. knrd Cupcake Jun 21, 2019
    knrd, Jun 21, 2019 :
    Hello guys.
    If you haven't gotten any error with OnePlus launcher is it possible to reboot device safely and successfully?
    #76
  17. Drewgaren Eclair Jun 21, 2019
    your better off installing another launcher and setting it as default
    #77
  18. JigneshJain Froyo Jun 21, 2019
    update this works good had rebooted 5 times no issues seen but I also kept twrp and adb debugging on in case if any issue faced.
    Try this only if you know what you are doing.
    If you ask me you got X problem I will laugh on you
    #78
    Drewgaren likes this.
  19. Andy lone Gingerbread Jun 21, 2019
    #79
  20. apat26 Froyo Jun 21, 2019
    apat26, Jun 21, 2019 :
    So first dp1 and then update to dp2 working good? No major issues in rom?
    #80
