101
Android Q Developer Preview 2 for OnePlus 7 Pro & 7
  1. Drewgaren Eclair Jun 21, 2019
    Drewgaren, Jun 21, 2019 :
    launcher working?
    #81
  2. bibhab1976 Gingerbread Jun 21, 2019
    bibhab1976, Jun 21, 2019 :
    Dear Friend, Plz dont even try to install this. this is worser than dp1. I have installed and it is extremely laggy and when i tried to delete the cache i got bootloop. At the end i have to use unbrick msm tool to make mey device work. This is not at all stable and a daliy driver. so my suggestion to everone plz dont install this if you donot know how to wake a bricked device. It is highy dangerous to install this dp2 version.
    #82
  3. apat26 Froyo Jun 21, 2019
    #83
  4. athrav Cupcake Jun 21, 2019
    athrav, Jun 21, 2019 :
    Indian brothers here.... Please suggest tempered glass for op7 pro from Amazon or any other online website.. Bcos i ordered one from Amazon dint worked no glue at all
    Kindly tell which one you r using and is it working properly??
    #84
  5. G_GOPALAKRISHNAN Donut Jun 21, 2019
    #85
  6. Helder_DAlmeida Honeycomb Jun 21, 2019
    #86
  7. anasmhds Eclair Jun 21, 2019
    anasmhds, Jun 21, 2019 :
    Its not worth to install as a daily driver specially you may end up with brick your phone if update the launcher it wont reboot. and in my case i lost my recovery (i did nothing wrong), i did recover my phone, however, i tried both H2os and O2os beta, the H2os is better but both have bugs and cannot be used as a daily driver.
    #87
    rahulpatil2009 likes this.
  8. anasmhds Eclair Jun 21, 2019
    I have my Pixel 3 XL beta rom, i am using it as a daily driver with minimum issues.
    #88
  9. JigneshJain Froyo Jun 21, 2019
    JigneshJain, Jun 21, 2019 :
    another update, changed fonts to OnePlus slate and it bootlooped. so cleared data partion from recovery and again started using it.
    I think issue is with data partion can't be mounted in twrp so it keep behaving like this
    #89
  10. Wireeater Cupcake Jun 21, 2019
    Wireeater, Jun 21, 2019 :
    Why are you asking this in a thread specifically for a Q beta preview?
    #90
  11. Wireeater Cupcake Jun 21, 2019
    so aside from the crash loop with the plus one launcher after store update (fixed by removing the update), I noticed that the emergency rescue section crashes when you try to change the emergency call trigger. I usually turn that off since I've accidentally called 911 one lol
    #91
  12. athrav Cupcake Jun 21, 2019
    Then where should I ask it?? Where I don't even get response?
    #92
  13. F1558274826852 Cupcake Jun 21, 2019
    #93
  14. apat26 Froyo Jun 21, 2019
    #94
  15. nishant_713 Eclair Jun 21, 2019
    nishant_713, Jun 21, 2019 :
    Dark theme working anyone? My settings page still white. Whereas qs shows no text only icon (black on black I think).
    #95
  16. BraydenM99 Donut Jun 21, 2019
    #96
  17. stefan_ddorf Jelly Bean Jun 21, 2019
    stefan_ddorf, Jun 21, 2019 :
    This isn't an Open Beta, it's still an Dev Preview!
    #97
  18. 7r.st1 Froyo Jun 21, 2019
    7r.st1, Jun 21, 2019 :
    Works great! Having some issues with OnePlus Launcher and Gesture Navigation, but what can you expect..
    #98
  19. D1546152220564 Cupcake Jun 21, 2019
    #99
  20. Lunatico Jelly Bean Jun 21, 2019
    Lunatico, Jun 21, 2019 :
    How about you and your "Indian brothers" take the discussion in the proper thread?
